Results 1 to 4 of 4
Thread: Auto to manual swap - R154 tranny
    Default Auto to manual swap - R154 tranny
    hey guys,
    i'm selling my drivetrain which includes the following:
    -R154 from a 1JZ: low miles according to previous owner, no grinds (includes all sensors, covers, hub w/ new throwout bearing, rings and washers, fork)
    -new 1JZ bellhousing
    -new 1JZ flywhell and new flywheel bolts
    -new Horsepowerfreaks ferramic clutch kit w/ new pressure plate bolts
    -Brake and Clutch pedals
    -Clutch master and slave cylinders including line from master to slave
    -full driveshaft, mk3 front and sc300 rear (no rear guibo/flex disk as it is cracked)
    -tranny mount
    -modified w58 shifter which puts it in the correct location (one member has said that shifter may need to be rewelded but i don't bang through gears and am not afraid of breaking it. solid enough for me)
    -rubber shifter boot (may want to get a new one as i ripped mine a little trying to run wiring for my cutout)
    -leather shifter covering (don't know what you call it but it's the interior shifter piece)
    -1jz and/or lexus 5 speed knobs
    when I say "new", parts have 1.5k miles on it after install. the only things missing that i can think of is to get a new pilot bearing and new guibo. this should be pretty much all you will need to do the conversion.
    please take a look at my sig for link to some of the parts for now. i'll try to get pics soon.
    $2000 for everything. am currently not parting out unless i get different buyers for everything...locals are preferred also due to size and weight. lowballers will be ignored
    tranny/bellhousing/front driveshaft(have the rear as well, just not pictured):
    clutch, hub, release bearing, and washers when new:
    disk when new:
    flywheel when new:
    marlin crawler shifter bushings:
    modified shifter:
    how the shifter sits in the car. leather boot and knob:
    i'll see if i can post up other pics later of pedals, etc. thanks for looking
