Results 1 to 14 of 14
Thread: D16Z6 Intake Manifold Vs. D16Y8.
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Exclamation D16Z6 Intake Manifold Vs. D16Y8.
    Which would be the better choice? And will the Z6 work on my '98 Civic without any problems? Thanks.
    y8 manifold is better.
    Southside Ridin HATCH
    x2 Y8 is better....
    I had one but i cut it all up!!
    Middle Ga.
    Quote Originally Posted by Black4DrEK
    x2 Y8 is better....
    Ah, you suck! I need one still.
    Athens/ATL
    y8 intake and exhaust manifolds are more free-flowing than the z6, which is the main reason for the slight hp increase between the z6 and y8. So if you've got a 98 civic, stick with whatcha got! lol
    y8
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    is the power that the y8 manifold yields over te z6 manifold wort the money and time you put into it?
    98 Acura Integra LS-DD
    ??????????????????-project
    Athens/ATL
    Quote Originally Posted by b18ej1
    Is it worth the 100 or so dollars (if even) you spend on it and the 45 minutes it takes to change manis? Yes. Yes it is. OE Honda parts > Aftermarket
    Middle Ga.
    Well see i'm not worried about changing it because i'm doing the head swap so it will be in order. I just have to find one now!
    TALKING ROCK, GA
    how much different is the y8 mani from the z6? fatter runners, bigger inlet or what?
    Where Am I
    their not that different its manly just easer if u have obd1-z6, obd2-y8.... Its worth doing if u can get one cheap I got my y8 for $40 with everything but I wouldn't spend no $100 on one, no way.... Get an auto man, with auto throttle body, so u don't have to wire for the IACV. Makes it SO!!! much easer....... D-Series.org is ur friend...
    TALKING ROCK, GA
    okay thanks...you got any bi-xenon hid kits you wanna get rid of by the way, tj?
    turbos
    Quote Originally Posted by Turbodude06
    x2
    But I believe that it has been stated that the y8 has a tendency to run certain cylinders lean. I will look for the link
    TOO BIG
    TALKING ROCK, GA
    Quote Originally Posted by seanrg1116
    x2
    interesting...repped
