Results 1 to 16 of 16
Thread: Door skeleton
    Southside Ridin HATCH
    Default Door skeleton
    Hey guys I have a big dent in my Driver door, and wanted to just by the SKELETON and get it put on my door??
    Were can i get the 'Skeleton' Put on my door.. And a legit place that knows what there doing?
    Or can i do it myself?? with the correct tools.... (welder, ect.)
    Canton
    Do you mean Door Skin? Because the skeleton is the frame of the door.
    Try not. Do or Do not.
    i drive slow im_hung's Avatar
    location, location
    it would be cheaper for you to get another door.
    AWOL keva52's Avatar
    Monroe
    just go to your local auto salvage yard and get a new door.. its like $50..
    O ok... I dont want to go to a junk yard and get one, cuz i dont want it painted some diff. color...
    The skin i can get off the web comes black...
    So it would be cheaper? how much for this to be done?
    Canton
    They are a pain in the ass to install from what I have heard. Just buy a salvage door and repaint it.
    Unpainted EM1 Zhu's Avatar
    Paintless dent removal?
    WTB: Driver's Side Sunvisor for 96-00 Civic
    FUK IT! bowdown201's Avatar
    Next Door
    Yea ive heard they were a bitch to install
    Quote Originally Posted by Black4DrEK
    Most body shops can do it, its really easy to do yourself I have done a few in the past not to bad if you have the right tools!
    ^ thanks.. what tools needed... weld, ect.?
    Miss my Civic.
    ehhh. Im sure SOME cars may be easier than others, but I dont think its an at home job.
    Quote Originally Posted by Sentra
    why not I have done them at home, and also in a wal mart parking lot
    Newnan
    door skins online are aroun 150-200..
    just get one from certifit or a parts yard.
    learn to english
    you won't be able to put a door skin on yourself. Sheer ability and knowledge is what you lack. You need a big grinder to go around the edges to take the old one off, Just grind until a line shows up and the inner edge of the skin releases. You are probably gonna need a smaller die grinder with a cutting wheel to grind out the smaller spot welds. take another die grinder with a stripping wheel on it once you get the skin off, and clean off all the old panel bond off the door frame. Scuff the back side of your new door skin. Put some new panel bond on the surface of your door skin where the door skin meets and make sure to cover all the metal. Put some seam sealer on the points on the frame where the skin touches the intrusion beam. Just glob it up on the old spots. Put your skin on the door frame, and then starts the fun part. turn the door over on your fender stand(do you even have any of these?) and then get your hammer and dolly and start to hammer it on. go around it at least 3 times, being very firm with the flat dolly on outside of the skin. If you don't have it firm then you'll beat the shit out of the skin and frame. don't try to beat it on the first pass. Then once you get it on and beat on all the way put the door back on the car and make sure it fits, have some vise grips holding on the top, if it welds there, if it beats on too, then get to town beating it on too. Get some paint paddles and wedge them and move the skin around while it is closed on the car, then, since you probably don't have a heat lamp, like a big one. Just leave the car sitting overnight. The next day, get 80 grit on a sander and sand the front of your door skin down. If you have dented it or warped it you will need to put some filler on it. Turn the door over and wipe seam sealer all pretty along the line of the skin. Then once it all dries prime as necessary, then get to painting.
    Think you have what it takes to do it. I did one tuesday, but I've done plenty. I work day in and out at a shop. If I were you I'd buy a door that isn't destroyed.
    GL either way.
    Athens/ATL
    ^^ Well there's your detailed write up lol.
    Seriously... just replace the whole damn door. Way easier and cheaper in the long run.
    Ok ill jus deal with the dent for a while.. .till i get new door....
