Results 1 to 8 of 8
Thread: help with idle problem
    Default help with idle problem
    i have a 96 civic with d16y8. alright i had a idle problem that was jumping up and down but now i change tps ivac and map and cleaned everything. and stop jumping now the rpms at idle are very high 2500 what do i do? thanks can it be the pcv valve?
    YEAH! bRiAnMcIvIcS's Avatar
    Douglasville
    Adjust the idle screw on the throttle body.
    Boost under slow construction...
    how do i do that?
    barrow county
    check your idle air control, normaly when its out you'll jump up and down
    Certified Gearhead schia89's Avatar
    Oct 2008
    its a little screw on the throttle body jus get a flathead screwdriver n adjust it till it normal
    Southside Ridin HATCH
    ^ do that...
    also could be vac. leak
    did you lose the rubber gasket on the iacv when you pulled it off to clean it? you have a major vac leak it sounds like. pull the intake tube off and cup your hand over the mouth of the throttle body. if the car keeps running and just drops idle a little then it's taking in air somewhere other than the throttle body.
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    if it has a fast idle valve on bottom with coolant lines on it that could be it! happend to a friend of mine and me twice. i just find a throttle body without it and runs great.
