Thread: bad idle/bad stuuter on every other gear/limp mode
    F.A.N.A.T.I.C. primespark22's Avatar
    Default bad idle/bad stuuter on every other gear/limp mode
    when my car is on neutral the idle is crazy going from 1500 to 1000 and evrywhere in between,when i put in 1st it drops to 500 almost stalling then come back up then on evry other gear i have to give it gas if not it will sputter and jerk,i have no cel and my car is on limp mode,what can cause these problems?
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    ... ŁG2♣'s Avatar
    2o9
    what kinda car? and motor?
    95 civic coupe with a b18c type r
    Augusta Ga
    bad ecu ? get a perfectly good ecu from a friend that you know works . and test it out ... if that solves the problem .. get another ecu .
    93 sol Si
    95 sol S
    95 sol Si
    yeah thats going to be hard since i have no friends with civics all of them got vdubs and srt4s lol,but ill get a hold of one
    Certified Gearhead Le_Stat's Avatar
    MACon G.A.
    mine kinda doin the same thing when i start off in first it acts like its fixin to cut off and i gota rev it to about 2.5k to get it to take off right ive replaced the spark plugs and the rotar buttton and its still doin the same thing
    ive got it ive freaking got,fixed the vtec wires adjusted the dizzy mthen reseted the ecu,i took out for a run and punched the gas expecting the car to red line 5500 since it was in limp mode but when it hit 5400 where a programed the ecu to kick in vtec the mofo took off,im stocked ima see if i can get a vid and post it,
