Results 1 to 19 of 19
Thread: EH, sluggish at low rpm's??
    Default EH, sluggish at low rpm's??
    SOLVED! .. stupid coil thingy
    ALL CAPS JITB's Avatar
    did u check your spark with a timing light? disty might be giving u the finger..
    vaccum leak?
    sounds like something basic.
    Stang Mod slostang's Avatar
    Southside
    im gonna say cat. hows it idle?
    im willing to bet its something basic ..
    idle? it idles pretty much perfect, stays at a constant 2 when cold.. then 8-900ish rpm when at temp.
    if i hold the gas steady at around 2k rpm.. itll fluctuate up and down just a wee bit,about 200 rpms if that matters
    so it only does it when you put a load on the motor?
    I know, I know!!!
    It's a honda.
    That's all.
    yep, pretty much....
    Quote Originally Posted by E36 M3,SRT4,WRX , LS1 fbody,RSX, EP3, MB CLK430s
    I know, I know!!!
    It's a honda.
    That's all.
    maybe, but its my only car and id like for it to run optimal so none taken
    lol. just messin' with you man.
    crank that timing light..out and check that spark one more time..
    will do, update tonight on what happens..
    updated... timing is good, both ignition and cam timing
    Certified Gearhead jdmda9's Avatar
    my car did the same thing with the old swap. i really just came to a conclusion that i had bad compression and the motor had stopped making power as it used to. but i never knew what was up with that swap. it basically ran like shi.T!!! eventully one day my timing fu.cked up and i had bent my valves! but since you said the timing is good, i think your motor is losing compression. but i may be wrong. gl with getting it fixed!
    shhh...
    vtec game scArY. . !
    Quote Originally Posted by jdmda9
    hrmm... well, i just did a compression test in the rain lol
    numbers are 215-215-215-215
    my engine sure has been acting strange lately ...
    JDM TYTE AnthonyF's Avatar
    Hmm...if is good (plugs, fuel, etc...) Change your oil and see what color it is. I'm GUESSING you might have eaten up your bearings.
    -Ant.
    The Carbon Fibered R6
    Certified Gearhead schia89's Avatar
    Oct 2008
    No codes showin up, jus like the guy above change ur oil n what kind of gas you use 93?
    i drive slow im_hung's Avatar
    location, location
    could be bent valve(s)
    LS Resurrection
    Fulton County, Union City
    checked your dizzy and plug wires?
    Quote Originally Posted by mikegsr
    He had the same compression all across. He also would have heard engine noises. You can drive around on chewed up bearings...I know.
    -Ant.
    eh, i found the problem...
    it was ASSUMINGLY the coil in my dizzy, i changed it with another one i had laying around and the sluggishness is no longer in existance. yay
    everyone will be repped for your time and advice
