Results 1 to 4 of 4
Thread: Possible dumb question: Replacing exhaust manifold gasket?
    Apr 2003
    Default Possible dumb question: Replacing exhaust manifold gasket?
    I have recently sprung and exhaust leak on my 94 GSR and it is coming from the exhaust manifold where it meets the engine. Would you need to remove the exhaust manifold completely to replace the gasket?
    99 Acura Integra
    Toyota Tech
    Dec 2003
    Claxton, GA
    have to be able to get it back far enough to clear the studs at least
    sounds like a cracked manifold if so you can weld it back together
    Quote Originally Posted by dragnGSR
    unbolt the 2 bolts on bottom backside on the manifold. where it attachs to the engine by the cat. then unbolt bolts on the manifold. slide header back about 2" replace gasket done.
