Results 1 to 10 of 10
Thread: ENERGY SUSPENSION REAR TRAILING ARM BUSHING
    Default ENERGY SUSPENSION REAR TRAILING ARM BUSHING
    have anyone replaced theirs for ESuspension bushing for their rear trailing arm bushing on 94+ integra?
    whats the xperience? better/good/soso or POS ?
    /Oo ___A___ oO\
    |=_/_______\_=|
    Sandy Springs
    The problem with Poly bushings in the trailing arm it that they dont allow the proper movement, they "bind". A poly bushing is only really good for a single axis movement (shock bushings, inner LCA bushings) and the trailing arm is on 2 axis'. Your best bet is to get an OEM bushing.
    whats the worst could happen? will it damage anything ??
    /Oo ___A___ oO\
    |=_/_______\_=|
    Sandy Springs
    Wont damage anything. I guess it would only be noticeable if you tracked the car or drove it hard. You might not ever notice though.
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    i was read that it will squeak if not installed properly
    90 Integra....Sold
    96 Jetta VR6...current money pit
    They will probably squeek even if they ARE installed properly. Even with their lube most poly bushings squeek a good bit.
    where can i borrow this tool that extracts the bushing off?? Or buy locally in cobb county?
    /Oo ___A___ oO\
    |=_/_______\_=|
    /Oo ___A___ oO\
    |=_/_______\_=|
    i drive slow im_hung's Avatar
    location, location
    If you have an air hammer you can get them off. I've done them many times with the flat head attachment. to get them in can be tricky... if you lubed it up and got it out, make sure you clean it with brake fluid, you need it to be dry in order to get them back in right.
    taking out the old bushings is not the problem, it's re-installing my ES bushings, and i'll definately need the tool
    /Oo ___A___ oO\
    |=_/_______\_=|
