Results 1 to 14 of 14
Thread: Wheel Knock Noise
    IS300 NEMO's Avatar
    We Fuckin...
    Default Wheel Knock Noise
    I have a 96 integra. I am starting to get a knocking noise from the driver side front wheel area from what i can hear.
    it only makes the knocking noise when on the throttle. when i turn to the right it does knock as bad but when i turn to the left a little starts knocking.
    axle or wheel bearing? axle apears to be fine.
    thanks for the help
    f-ckouttahere. PROŽ's Avatar
    CV joint perhaps
    JDM TYTE AnthonyF's Avatar
    Sounds just like the explorer issue, check caliper bolts and wheel lugs first. KISS method:
    Keep
    It
    Simple
    Stupid
    -Ant.
    The Carbon Fibered R6
    IS300 NEMO's Avatar
    We Fuckin...
    Middle, Ga
    Sounds like CV joints to me.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    IS300 NEMO's Avatar
    We Fuckin...
    why would it only knock when on the throttle?
    Columbus
    cv joint is my vote...its really typical on tegs. both of mine did it. couldn't tell you why it does it when you accelerate though.
    jack the car up and see if the boot is torn at all. also its alot easier to replace the whole axel if the cv is bad.
    Shibby hurlyfire7's Avatar
    i agree with the cv joint..
    had this problem before on an 02 corolla
    Atldm dude...
    :boobies:
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by 99jdmLs
    i looked and didnt see torn. thanks for the info. just bought the car so i might end up replacing the axle ne ways.
    IS300 NEMO's Avatar
    We Fuckin...
    so i just replaced the drive axle and took it for a test drive and its still knocking.
    ne idea?
    Senior Member 4DrTeg's Avatar
    umm mine did that kinda but it was due to a broken camber kit..could check that
    in dabuilding
    wrong its not the cv axle i had this problem on my 99 civic i never found out wat it was i sold it but its not the axle
    i drive slow im_hung's Avatar
    location, location
    check the radius rod bushing. I've seen them go bad @ times
    IS300 NEMO's Avatar
    We Fuckin...
    i didnt see ne thing wront the the camber when i was replacing the axle
