Results 1 to 23 of 23
Thread: serious help needed
    Default serious help needed
    car won't crank. : ( i thought it was for sure the starter so i bought a new one and nothing...it wont do anything turn the key and nada....worked fine till mid day yesterday. i need help any ideas?????????????
    Sandy Springs
    My first thing that I would check is put a test light on the wire to the starter. When turned to start position you should have 12v.
    But if you dont have 12v at the starter wire and the fuses are good, there is either a break in the wire or the ign switch is bad.
    Heres a pic of the starter circuit. Hope it helps.
    Default thanks
    i got 12 volts. which fuses should i check. if i pop start it and then turn it off but quickly turn it back it'll crank. don't know if that helps...i'm really screwed if i can't get this running tonight. also i was messing with the head unit and now when i have the car in the on position the radio in on but when i go to start it it turns off. could there be something wrong there? i tried completely unhooking it and get the same issue
    Sandy Springs
    okay, when you said "new" do you mean new new or just anther one?? If you are getting 12v to the small starter wire AND the big wire then you have a bad starter.
    BTW, the radio will turn off in the start position. All cars do that.
    yeah i mean brand new... i didn't check the big wire to the starter. just the small one.
    actually now i'm not sure if i am getting 12 to the small one but i am sure about the big one lol...i hate my multimeter.....could my alarm somehow be messing with something in the ignition
    Sandy Springs
    If your alarm has starter diasble then yes. If its just a plain alarm then more than likely no. Just make sure you do or dont have 12v at the small wire when in the start position. If you dont, then youll need to back track toward the ignition switch.
    If you NEED to move the car or get somewhere, you can "hotwire" it. Be SURE the caris in neutral and turn the key to the one position. Then take a piece of wire and jump between the big wire terminal and where the little one on the starter. Youre basically bypassing the ignition switch.
    what time is lunch?
    woodstock
    it is your ignition switch.
    If you can start it and it stops immediatedly then starter switch.
    Bad contacts on the little white plastic thing behind the key switch. My rex did it. I could start it but it would immediately die. Or driving along and it would die.
    There is a white ring with with contacts in it attached to your key switch. This is tied into your ignition harness.
    They are about $40-60 from honda.
    Default update
    Well I got it fixed today. The little blue button in the clutch broke. So we straight wired it so I don't need to push in the clutch anymore to start it. Thank you so much for trying to help out
    Southside of The Jungle
    Quote Originally Posted by jriley60
    Same shit happend to me day of the V meet next day found out clutch switch went bad and I just bypassed it car started right up
    college park
    lies
    when did marta start having manuals on the bus
    now with LSD
    lies
    Brothers Coupe So STFU
    Sandy Springs
    hmmm, it didnt show a clutch switch in the wiring
    Glad you got it fixed though
    Senior Member sakasaku's Avatar
    Marietta, GA
    Neutral Safety switch, glad you figured it out
    Lurking
    Sandy Springs
    Neutral safety is for automatics, clutch switch is on sticks.
    what time is lunch?
    woodstock
    na it is called a neutral safety switch/ clutch switch can not start until press in clutch.
    The little blue button you are talking about is the same as the brake pedal. My suggestion replace the little button on the clutch as well as your brakes.
    you will get in your car one day and have brake lights on all the time.
    I've got the honda part number if needed.
    Marietta, GA
    Quote Originally Posted by rbwdriven
    Yeah when ever i hook up my battery my third brake light wont shut off....
    Lurking
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    LOL
    what time is lunch?
    woodstock
    honda part number
    46505-SA5-000
    I think they are a buck a piece.
    the new ones are white versus the old blue ones. You will have one for the clutch and one for the brake.
    Marietta, GA
    i am missing the little rubber grommet that goes over the button and it wont push the switch in without it.... is this what this is?
    Lurking
    Southside
    Quote Originally Posted by sakasaku
    Yea I had the same problem a few years back, but seen it and replaced it
    college park
    dont be so mean corey sheesh *runs away*
    now with LSD
    Marietta, GA
    i got it yesterday... its a cone shape i put it in and my third brake light shut off!
    Lurking
