Results 1 to 40 of 52
Thread: Honda/Acura Parts! Everything is OBO!
    Warner robins ,Ga
    Default Honda/Acura Parts! Everything is OBO!
    Im trying to get rid of everything so i can pay for bills!
    I have an NA LS bottom end
    -B18B1 block honed/decked/hot tanked at reeves
    -block code:6313988
    -pistons: OEM honda CTR std size machined to fit LS rods at reeves
    -rings: OEM honda std size
    -crank: b18B1 balanced/micro polished at reeves
    -rods B18B1
    -bearings: ACL duraglides rods, main, thrust washers from patrick4588
    $450 OBO
    -Honda GSR oil pump $50
    -B-series Moroso oil pan $95
    Brian Crower all motor Stage 2 cams for b18a1/b18b1
    PN# BC0022
    used for 2000miles
    SOLD!
    Gold Eagle cam gears for B-series
    used for 2000miles
    $100 OBO
    jdm D15B vtec valve cover
    $50 OBO
    A bunch of stuff for brake tuck -3an fittings
    40/40 prop valve
    $100 obo for everything pictured -10an fittings as well
    H22A turbo manifold elephant top mount style
    missing a turbo flange but i have a t3/t4 flange can give you.
    $60 obo
    Full d16a1 swap came from a 89 integra ls
    [came off of DeeAone's car]
    running when pulled
    come with a jdm pm7 ecu
    its 5spd
    needs axles
    everything is pictured
    $350 obo
    perfect swap for older civic[will get ef with lil modification on the mounts.]
    JDM eg rear seat.[green]
    its dirty
    $55 obo
    i have a 92-95 civic ex driver side coupe. power window and lock. [hatch/coupe] $50 OBO
    B-series hydro LS tranny grind 2nd and 3rd at high rpm
    but you cannot down shift into 2nd pass 10MPH.
    $200 FRIM
    b18b1 stock complete head.
    no valve cover
    118k miles
    $75 frim
    Thanks for looking!
