Thread: 1998 eclipse gsx
    Enterprise AL,
    Default 1998 eclipse gsx
    ok im lookin at buyn a 1998 gsx awd turbo 5speed it has a bad trans what kind of trans can i put in the car does it have to be a 98 gsx only?
    Total Insanity helcat17's Avatar
    macon
    i would think that any trans out of that year eclipse would work as they all had the same bolt patern on the bell housing but be verry carefull about going DSM crank walk FTW!!!
    2009 Honda Civic
    2006 Honda CBR1000rr FS/FT
    http://www.importatlanta.com/forums/...d.php?t=211300
    There is a small difference. On the the 2G's the transmission have (I think) 3 mounts on them. The 1G transmissions only have one mount on them. The bellhousing bolt patterns are the same, but the plate that the starter goes on is also slightly different.
    Quote Originally Posted by MR.org
    my god, check the classifieds for a trampoline, youre jumping all over the place here,
    warner robins
    probably have to get a gsx tranny because of the transfer case............
    JJSPEC.COM
    Warner robins ,Ga
    '05 GSX-R 750 Sushi's Avatar
    Mall of GA
    Quote Originally Posted by xdavidscenex
    End of Thread.
    2005 Suzuki GSX-R 750
    Boost is your friend $9ktt's Avatar
    Disgusta, GA
    Any 5spd out of a 95-99 GSX will bolt right in. Any other years, 90-94 will have different mounts and different front axles.
    B
    ps: CW is not as common as most people think BTW.
    pss: also look for a 5spd trans out of a 95-97 Eagle Talon Tsi AWD
    Dunwoody
    EVO 3 trans will also work.
    Certified Gearhead koi's Avatar
    Covington
    95-95 tranny will bolt in. But there is a difference. Best bet is to call Shep himself and have it explained to you.
    Now saying that, If you do get a 95-96 tranny. Make sure you get the transfer case that will go with the 95-96 tranny. Same as the 97-99. My last car was a 1996 awd spyder. I had to check and make sure everything matched.
    Here are the codes that will help you also.
    W5M33-2-NQBK 91-2 Galant VR4 up to 4/92
    W5M33-2-NQBM 92 Galant VR4 mfg 5/92
    W5M33-2-NPZS 89-90 Eclipse AWD 5spd turbo mfg 3/89-6/90
    W5M33-2-NPXV 91-94 Eclipse AWD 5spd mfg 6/90-2/94
    W5M33-2-NNZT 95 Eclipse AWD 5spd mfg 3/94
    W5M33-2-NPZT 95-96 Eclipse AWD 5spd mfg 3/94-6/96
    W5M33-2-MUZT 97-99 Eclipse AWD 5spd turbo mfg 7/96-end
    Koi
    Proud former owner and future owner of a 1996 Mitshibishi Eclipse Spyder GSX(AWD). Ready to sell it back to me yet, Vonrok?
