Maybe some of you can give me some more insight.
I've got a 1986 Starion.
Factory fuel pump went dead ages ago and the previous owner installed a Walbro 255 and had the tank vatted and recoated by a radiator shop. When he did this he replaced the factory banjo bolt fuel filter with a Summit racing filter with a 40 micron stainless steel replacable element and revomed both filters between the pump and tank.
Fast forward to a couple weeks ago, felt like fuel pressure was dropping. Bought a Fuel pressure gauge and verified under driving conditions the fuel pump would drop pressure instead of increase.
So i replaced the pump and added the 2 filters between the pump and the fuel tank. First it would not pull ANY fuel from the tank. So i primed the system and the car will idle just fine now and build the correct amount of pressure. But I still have same problem. Actualy, the problem is worse. The car will sit and idle just fine at 40psi, but as soon as i touch the throttle to move the car the pressure drops.
The only thing i can think of is that the front filter is so clogged that its restricting flow and making problems for the rest of the system.
I'm also using an Aeromotive rising rate FPR that was bought brand new and installed into this car. A friend of mine think its one of 2 things, either the pick-up tube is pressed into the pick up screen too closely and not creating enough vacuum or the FPR is faulty in some way.
I don't think its got anything to do with the pickup screen because i had the hose coming off of the pump running into a cup of fuel and it would not suck ANY fuel out. That was before i primed it.
So, I'm going to check that front filter, probably tonight. but the only way i can think to check that FPR is to replace it and try that.
Any ideas?
