Thread: I Need Help With A ZC Motor
    Woodstock, Ga
    Default I Need Help With A ZC Motor
    ok i have a code 19 on a 91 civic hatch with a ZC swap anyone know what that code means??
    are you sure its not, one and nine, cause 19 is for auto trannys.
    Woodstock, Ga
    yeah my bad its one and nine
    EF Squad
    hope this will help:
    0 Engine Control Module (ECM)
    1 Heated Oxygen Sensor (HO2S)
    3 Manifold Absolute Pressure (MAP Sensor)
    4 Crankshaft Position (CKP Sensor)
    6 Engine Coolant Temperature (ECT Sensor)
    7 Throttle Position (TP Sensor)
    8 Top Dead Center Position (TDC Sensor)
    9 No. 1 Cylinder Position (CYP Sensor)
    10 Intake Air Temperature (IAT Sensor)
    13 Barometric Pressure (BARO Sensor)
    14 Idle Air Control (IAC Valve)
    15 Ignition Output Signal
    16 Fuel Injector
    17 Vehicle Speed Sensor (VSS)
    20 Electrical Load Detector (ELD)
    21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
    22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
    23 Knock Sensor (KS)
    30 A/T FI Signal A
    31 A/T FI Signal B
    41 Heated Oxygen Sensor (HO2S) Heater
    43 Fuel Supply System
    code 9 is usually caused by the distributor
    Woodstock, Ga
    Quote Originally Posted by Tensa_Zanget
    16 Fuel Injector
    30 A/T FI Signal A
    31 A/T FI Signal B
    damn dude i have been looking everywhere for that lol.... thanks man
    Snellville/Statesboro
    a good site for ZC technical questions is www.thezcr.com
    UPROOT Photography FTW
