Thread: How do i replace a Lower ball joint
    Norcross
    Default How do i replace a Lower ball joint
    need to replace my lower balljoint for my 92 civic. Yes i did search, but im wondering if anyone can give me some tips/pointers
    Jonesboro/Stockbridge
    I think it has to be pressed in, I may be mistaking though. Lol
    Quote Originally Posted by JDM onlyy
    Correct.. You can rent a ball joint tool kit at the Autozone for 90 bucks use it and then take it back!
    Works great!
    Back from R&D Land
    Back from R&D Land
    Yes it is pressed in. If you don't have the tools, you can take the knuckle assembly to Napa and they will press them in/out. Most Napa's have this ability.
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    Nuh Botha Mi chameleon30038's Avatar
    Gaza Mi Seh
    Works great!
    Answers right here!!!!
    i drive slow im_hung's Avatar
    location, location
    to get them out use a air hammer with a pointed end. you want to aim and the joint(near center) they should come out real easy. ive replaced alot of bj's at honda...
    or
    you can get technical
    http://www.zshare.net/image/557442715edac3a0/
    \m/>_<\m/ dorin48's Avatar
    Canton
    Another common option is to pull the knuckle off the car and then use a mallet instead of a press. Just need to be careful not to damage anything while your wanging on it.
    Norcross
    thanks for the replies. repped
