Results 1 to 16 of 16
Thread: Is an H22a4 a good motor to build
    Certified Gearhead Le_Stat's Avatar
    MACon G.A.
    Question Is an H22a4 a good motor to build
    ok i jus bought a h22a4 to put into my 96 civic and i was jus wondering if it was worth building cuz im planning on turbo the motor and was jus wondering if it was a real strong motor or not...thanx
    ohh yea if anybody has any parts or anything i might need for my swap plzzz let me kno....
    yes as long as it isnt the ATTS motor
    Better have some $$ saved up....
    2009 zx10R
    2005 919
    2006 xt225 dual sport
    Sleeve or bust.
    Macon
    Quote Originally Posted by Le_Stat
    In general, the motor is very strong. However, the FRM sleeves are the H22A4's Achilles heel. They do not hold up well to forced induction, especially if you are planning on running anything above 5psi or so. If you are planning on going all out, get it sleeved. It's not that expensive compared to the turbo kit you are going to potentially buy anyway. You won't be disappointed.
    Land Rover LR3 HSE
    ^^^ Very true ......
    I ran 7lbs tune on a stock H22A4 for about a year without any issues...But daily was 3-4lbs an high boost was 7 lbs....
    But yes do it right or not at all....
    Build 42% Done ACCORDPRIDE's Avatar
    In a pile a H22 parts
    like they said above
    great all motor engine but very expensive to turbo
    you can do as tech5 says and run low boost but thats all you can do without spending a good amount of change
    AKA HIZDAWAY
    MACon G.A.
    it came out of a 97 prelude so i think it is the atts motor is that bad?
    Well even with that it might not be, you have to look at the back of the block an see if it was for the atts or not...If it is you will not be able to use that block in a civic because it doesnt use a Halfshaft ...Only way you can use it if you know a Great TIG welder and install bungs so you can use the halfshaft...
    You can google this for pics and more info
    MACon G.A.
    so what is atts
    LS Resurrection
    Fulton County, Union City
    FRM = no overboring
    MACon G.A.
    could i jus use a b series tranny and not have the prob???
    Nope you still need a none ATTS
    Google ATTS prelude!
    LS Resurrection
    also he would need a h2b kit lol
    MACon G.A.
    ok i found a link this dont look like it will b that much of a prob
    http://www.preludepower.com/forums/s...d.php?t=278673
    Certified Gearhead 01CDMLUDER's Avatar
    You should of bought a JDM H22. They are closed deck and are better for boost. My cars been boosted for a while and no problems. As far as the atts goes they came from the SH model preludes. I don't know about swapping it into a civic but i know the atts doesn't like more than 250hp.
