Results 1 to 23 of 23
Thread: Can I get away with this?
    Default Can I get away with this?
    I just bought a 97 Blazer (4.3 V6) that has no oil pressure once it warms up. Has a very slight rattle above 3800+ RPM. No metal in the oil or old filter (did oil change today). Could I get away with just sticking a pump in you think?
    Edit: before anyone says thats shady or whatever Im not fixing it to sell Its my beater.
    BMW 750iL
    i had that same issue on a beater 96 camaro i had. replaced the oil pump it worked for all of 20 minutes. it needed new bearings.
    Thats whats confusing me, if it did why isnt it knocking or something?
    BMW 750iL
    mines didnt knock it had a slit ping or tap
    I also checked alldata... it says to remove the engine to replace the pump. Can it be done with the engine in the truck? Just take the motor mounts off and lift the engine up enough to drop the pan? If it has to come out Ill replace the engine before I do all that only to have it not be the pump.
    BMW 750iL
    See my other post please sir.
    BMW 750iL
    Quote Originally Posted by X-Runner
    that how i did it. took it off the mount dropped the craddle a lil. it still was a bitch but easier than taking the motor out that bitch.
    Ill probably give that a shot, the high volume pump is only $32 so I figure its worth trying. I love how alldata said to to do it.
    1. Remove engine
    2. Remove oil pan.
    3. Remove oil pump.
    Thats all the detail it gave, seriously.
    BMW 750iL
    1. Remove engine
    2. Remove oil pan.
    3. Remove oil pump.
    lol yah alldatas details at time blows try shopkey an see what it says.
    I dont have an account...
    BMW 750iL
    Just go to Pull-A-Part and get another engine for a couple hundred lol!
    Screw pull-a-part... A local junk yard here has one ready to go for $300 with a 90 day warranty.
    BMW 750iL
    Swap engines and fix the other one to sell or make a boat anchor out of it.
    I need to get a mechanical gauge on it first, this engine runs to good to not have oil pressure.
    BMW 750iL
    That's why the real name is Some-Data
    Well I just figured out it has a blown head gasket... 350 swap here we come!
    BMW 750iL
    Certified Gearhead shubert's Avatar
    jasper/canton
    my 4.3 "w" (throttle body non-vortec) had the same problem , all it was , was the oil sending unit. i put almost 100,000 miles on it when it started reading 0 psi. i actually had 372,000 on mine when i sold it. and it still ran dependable , and was almost all original (except starter , alt. , water pump , the usual maintenance)
    Quote Originally Posted by BTLFED View Post
    You are a load that should have been swallowed.
    86atlanta.proboards.com <-------Atlanta based ae86 and drift community!!
    jasper/canton
    do a 383. FTW!!
    My TBI 4.3 in the old 87 I had ran for 3 years with a blown head gasket but it was running out the exhaust. Had to add water every 4-5 days or so but ran great.
    BMW 750iL
    Quote Originally Posted by shubert
    do a 383. FTW!!
    Shhh
    BMW 750iL
    always good to know before doing major work on a car.
    Yeah, when its spitting coolant all over the place out of the radiator thats not a good sign
    BMW 750iL
    I need to stop being lazy and get done lol
    BMW 750iL
