Results 1 to 27 of 27
Thread: b18 swap.
    Banned civictR's Avatar
    in a shoe box
    Default b18 swap.
    okay, i i just finish my swap last night. 97 ls_v-tec in a 93 civic hatch and the fucking hood won't close. Seem like the cover are keeping the hood from closing properly. any one had this happen before and how do i get it to shut right..
    Thanks, thats Meeh
    well, if u wanna get it shut right. you gotta put the engine in my car, than the hood would shut. LOL.
    take a hammer and beat the shitt out of the cover and it will allow more room for it to clear!
    no no no, you dont wanna hurt the VTEC.
    in a shoe box
    yeah, try that last night with a 10lb hammer. but it didnt make a different. any other suggestion?
    in a shoe box
    Quote Originally Posted by hmong_Spec
    i bet.
    smash ur hood up?
    Quote Originally Posted by civictR
    in a shoe box
    i'll try that tonite. but any other GOOD WITH NO DESTRUCTION suggestion?
    in a shoe box
    BUMP
    college park
    what mounts are you using?
    now with LSD
    Southside
    Cut out the bracing on the hood that's preventing it to close.
    in a shoe box
    IM USING THE STOCK LS MOTOR MOUUNT. EVERYTHING FIT PERFECT. I HAVE 5 MOUNT TOTAL. FRONT TRANNY, TOP TRANNY, REAR , RIGHT , AND FRONT RIGHT(where the Ac compressor was).
    I SEEN SOME CIVIC AROUND HERE WITH THERE HOOD TILTED WITH A SPACER. LOOK KINDA GAY TO ME.
    Norcross
    cut out the skeleton in the hood
    i drive slow im_hung's Avatar
    location, location
    if you cut the support on the hood it may close, but you might have a problem with it getting scratched under load cus of the motor flex. your best bet is the putting a spacer in...
    Duluth, GA
    Quote Originally Posted by j0nbunklah0m
    that could work...but a hood prop is your friend
    in a shoe box
    so i should mod the hood then like this?
    yeh, i going to try to cut the inner skeleton off and see how it going to turnout.
    or the hood
    in a shoe box
    i guess no one on this forum did a swap like this before to know how to fix this problem properly. sad sad
    ive done more swaps than i can count never has this problem sry. ull figure something out your a bright boy.
    sounds to me they got the motor jacked up an aligned in wrong? I have done many swaps too now unless he has a H22 swap I might can see some issues lol so maybe he isnt sure what he has?
    or b20 and hasnt replace the IM.
    very true
    aye bro .:Stirfry:.'s Avatar
    i have a friend with the same problem but with a GSR..
    and its just the motor mounts, i say get some new ones
    for that swap and car.
    ATL DAsquad Member #9
    Senior Member Nang's Avatar
    what head is on it? tbelt cover is hittin
    well you can modify your hood and do wat some folks do 2 their hoods, for that JDM look, take off your hood find some misc (2) 11mm sockets and then tighten them down with some longer bolts to hold them up and your hood should sit higher, but leaves you with that JDM gap/room so hot air can breeze on through ..
    /Oo ___A___ oO\
    |=_/_______\_=|
    Quote Originally Posted by YouKnowIt
    he got it fix awhile ago. this was dead until somebody got bored.
    the county
    this swap i'm sure has been done many times, but with the rep you got, i would be throwing some bullshit answers at you too.
    you're climbing the ranks just like claybird did.
