Results 1 to 22 of 22
Thread: Water pump....HELP!!!
    Default Water pump....HELP!!!
    lol im so damn flustered right now its ridiculous. is this thing really that hard to replace?????? ive got the engine mount off and im tryin to get the damn crank pulley off but i cannot figure out how to get it off. Ive tried putting it in gear, ive tried having someone pushing the brakes and doing it that way. now ive got the tranny unbolted and .....drained of fluid..... but im starting to think that ive gotta take the pass. side suspension off so i can move the axle out of the way to pry the engine off.....
    can anyone help??? or give me some pointers or SOMETHING. if you could come by maybe tomorrow or wednesday even would be cool. ill pay for your time or lunch or beer or whatever just please help.....
    wow..... grrrrr......
    EF SQUAD FTMFW!!!!
    Southside
    Where do you live?
    Impact gun, holding the brakes wont do anything, neither will putting it in gear... (unless its that loose)..
    Or the special tool.
    Sandy Springs
    Umm, ive never hear of someone pulling the tranny for a water pump.....
    Like said before, impact gun or get the special tool. Some parts stores have this for rental. Not sure where though.
    im in lilburn.....
    the only reason im taking the tranny loose is to lock up the flywheel so i can take the crank pulley off...... or is there an easier way?
    EF SQUAD FTMFW!!!!
    I don't care cwhiteboy's Avatar
    Northeast atlanta
    An impact gun is your best bet.
    Southside
    Quote Originally Posted by SL65AMG
    im in lilburn.....
    I have the Hex tool to hold inside the crank and I have an electric impact
    Get the honda crank holding tool or a chain wrench.
    Northeast atlanta
    Quote Originally Posted by EJ1soSlo
    Well, do you have a breaker bar atleast??
    Southside
    Quote Originally Posted by cwhiteboy
    so 300 ft/lbs isn't enough but yea I have that tool green91 is talking about and a breaker bar yes
    ive got access to more tools than i know what to do with. also ive got an air compressor and a few air ratchets/tools; tools arent the problem. its my lack of experience.... lol
    and where would i go about finding one of these "crank holding" tools??? and how much $$$ are we talking to buy one?
    EF SQUAD FTMFW!!!!
    this is the kind of tool i need.... not the hex one....
    http://www.amazon.com/Alltrade-64882.../dp/B0002Q8TTG
    EF SQUAD FTMFW!!!!
    what time is lunch?
    woodstock
    All you need is tool above unless you have the hex crank.
    You will also need a pry bar to hold that tool.
    Then put in 17 mm socket onto nut with wratchet and use another pry bar to loosen.
    I've got both tools hanging from my wall. I can have the bolt loose in 5 minutes. My buddy uses mine all the time and he can have them free in about the same amount of time.
    where did you get that tool? i dont need the Hex one its not the same pulley....
    EF SQUAD FTMFW!!!!
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    dude put the tranny back on, take the flywheel dust cover off, stick a pry bar to lock the flywheel up and have someone break the crank pulley bolt off, the bolt is not really that hard if you have a breaker bar, the hard part is to get the crank to not spin, and the easiest way to do is to lock the flywheel up, just stick a pry bar in there and have somoene else break the bolt loose.
    Quote Originally Posted by PTY_REX
    that would have been great to know earlier.... lol
    i didnt take tranny off i just loosened the bolts. where is this flywheel dust cover? on the bottom or the side or what?
    than brings me to another issue..... refilling the tranny fluid. Where is the plug?
    is it the one towards the back of the tranny about halfway up???? or is there one on top?
    EF SQUAD FTMFW!!!!
    lawrenceville
    if tools are not the problem listen get a torch not to cut of the bolt but to loosen it up a bit you torch the bolt up till it starts to glow a little orange them you either grab 1(an old ratchet with the correct socket and you bang the top of the ratchet while jerking it trying to loosen it.) 2(or you just put an impact gun to it till compressor runs out of air) if the compressor cannot hold the gun for longer than 2min. at full blow then you need a bigger compressor. the reason for the torch is so that the heat can stretch the bolt out a bit.
    FYCN in a rick james voice
    lawrenceville
    take the passenger side wheel off and you'll see two bolts one with a square on it the fits a (3/8 drive ratchet) towards the bottom and a regular hex on top of it can't remember the size. I think the tranny only take 1.9 qts. of fluid so dont over fill it.
    make sure you fill on flat grounds and drain the old fluid before putting in the new one. royal purple syncromesh is really good. if fluid pours out the top hole let it pour out cause it means its too full. hope my info helps
    Quote Originally Posted by BLK_TEG
    ya i was thinking of putting a torch to it but my dad said "hell no you arent gonna torch it"..... or something along those lines.
    the compressor should be able to run the gun for 2 minutes without kicking back on????? i dont really see why thats relevant. ive got a decent sized compressor, like 15 or 20 gallons or something.
    EF SQUAD FTMFW!!!!
    what time is lunch?
    woodstock
    I got the tool off of ebay.
    If I were closer I'd say you can borrow it.
    crank tool
    you might be able to get it at napa or somewhere like that.
    Quote Originally Posted by rbwdriven
    crank tool
    thanks. just bought it.... not that it will be here in time but..... oh well
    EF SQUAD FTMFW!!!!
    so i just impacted the fuck out of this thing and its only turning the pulley itself, slowly. then i got to thinking....
    it isnt a reverse thread bolt is it????
    EF SQUAD FTMFW!!!!
