Results 1 to 22 of 22
Thread: Any b20b crx that passed emission legally?
    EF Squad
    Default Any b20b crx that passed emission legally?
    EDIT: PASS EMISSION WITH FLYING COLOR
    Additional notes:
    - Universal Magnaflow cat
    Here is my result:
    25/25 Test:
    Reading: Allowed:
    HC ppm 40 160
    CO % 0.00 0.90
    NOx ppm 2282 1179
    50/15 Test:
    Reading: Allowed:
    HC ppm 45 166
    CO % 0.00 0.93
    NOx ppm 3187 1304
    EF Squad
    woah no one with a b20b on their crx...
    I don't care cwhiteboy's Avatar
    Northeast atlanta
    Doesnt have anything to do with your engine, There is a piece of emission hardware that is not working properly, or your engine could have an issue (ie. timing). Try doing a search on the internet for "emissions failed NOx". That should give you some idea. For some reason, i'm thinking off the top of my head, O2 sensor, but i'm probably wrong.
    Snellville/Statesboro
    get an OEM cat, you'll be aiight.
    UPROOT Photography FTW
    what time is lunch?
    woodstock
    Yeah that is what I'm thinking looking at those numbers.
    I'll look at my past results. I know with high numbers we have done either new plugs and wires or o2 sensor.
    Northeast atlanta
    Ok, did some research for you. High NOx has to do with exhaust temperature, and yours is too high. If you have a high flow cat, that definately isn't helping you. Try replacing your egr valve, costs like 2 dollars and takes 5 seconds. Your engine is probably running lean, so try to figure out why, or retard your ignition timing a little, it may be advanced too much.
    Hope this helps. Let us know.
    Quote Originally Posted by cwhiteboy
    also, if you can get your hands on an OEM cat for a decent price, snatch that shit up.
    made my dad's b16 pass after we replaced EVERYTHING els
    Based on your HC and noX im going to guess its running a little on the lean side.
    EF Squad
    Well i dont have an O2 sensor and suprisngly i passed the other porition of the test.
    EF Squad
    I did some research a bit myself a few days ago and learned alot about it too. It did mentioned about the cat,egr, timing and etc like u mention. As or my cat i bought it online but it did say obd1 and obd2 approved and i really dont want to go thru the trouble of having to get a new cat cus then ill have to get it reweld and etc an it cost me alot for all that with the cat ig ot rite now.
    Again, thxs for all ur input! +1
    EF Squad
    I do have an oem cat but the bolt and nuts on that has been so long and old that it seems like it got welded onto the midpipe. Therefore, i was left to no choice but to buy a new cat. And that cat is a d series so it wouldnt not bolt onto the b series header. And i happen to find a cheap skunk 2 mega power exhaust a few weeks ago so i just went ahead and ordered the magnaflow cat converter.
    Reps to those that help!
    Southside of The Jungle
    Get O2 and make sure timing isnt advanced or retarded my friend had a sohc in his coupe and he advanced timing a little bit and forgot when he took the test.His car failed until he corrected the timing.
    EF Squad
    yea thats my next move but since i got a gsr header theres no O2 bung so i might have to get a bung installed by a muffler shop and its gonna cost me like $40 bucks just for a bung...
    EF Squad
    By the way if i were to register my car at a county that dosent require emission will that work?
    what time is lunch?
    woodstock
    yep all day long. you just have to provide a proof of residency.
    college park
    i have been doing that for years its the only really good thing about columbus ga lol
    now with LSD
    EF Squad
    Well i have a friend that lives in athen, ga and sooner or later i will be staying there since im transfering to UGA this upcoming fall so i might use his address when registering. How will i show proof of residency?? Does the title have to be under his name?
    Northeast atlanta
    I believe you need some sort of bill from the "claimed residency", like a power bill, phone bill, etc. Could be wrong though.
    EF Squad
    Anyone else know? i want to be 100% sure though.
    EF Squad
    any ef members know??
    YO MAMA
    dont be dumb and get it done the right way. Stop wasting your money and having to redo it the right way later on.
    EF Squad
    Quote Originally Posted by bibong
    Ur suggestion is absolutely right, but sometimes it will cost ALOT MORE to diagnosis or fix the problem that is causing a failure in emission.
