Results 1 to 32 of 32
Thread: This is our family.....
    Cobb County
    Default This is our family.....
    CREW, MAKE SURE YOU POST UP ASAP! please......
    LOL, forgot I had this picture, but this is about half of the crew in this pic.
    Figured I would make a thread to kinda introduce each of the members of BRB. We shall start with the High Commander (me, lol)
    Main Ride:
    1993 Honda Civic CX
    Mods:
    11.5:1 Pistons
    Eagle Rods
    Type R Water and Oil Pump
    Ferrea Valves
    Blox Valvesprings and Retainers
    BatlGround Header
    Stock Injectors, Fuel Pump, B16 Cams, Intake Mani
    LS Tranny
    Magnaflow Exhaust 2.25
    Rocket Man
    Dec 2008
    Griffin
    OldsTech
    It is 1987 Camaro v-6 coupe body. It should weigh alittle less then 3100lbs without driver (no options)
    The engine is a 1984 Olds 307 with 5A heads
    I overhaul it around 5 or 6 years ago I might have 5,000 miles since then
    The cranks was turned and reinstalled with clevite 77 bearings
    Honed and reringed with speed pro rings
    New cam bearings and a Comp Cam 268H .454./.454
    The heads were recondition (no port or nothing. Just new seals and valve grinding)
    And whateva is usually with a typical rebuild
    External:
    Edelbrock performer rpm intake
    K&N Airfilter
    Holley 670cfm Street Avenger, yellow spring on the vacuum sec
    Accel Blueprint dist with MSD guts and Cap with light springs
    Msd 6AL box with complete HEI Kit and blaster 2 coil
    Msd 8.5mm wires and NGK plugs gapped to .040
    Hedman Headers, 2.5 piping, X-pipe, and 2 dynomax Super Turbos mufflers
    No A/c, No Smog Pump, No Emission
    Electric Fan and Electric Fuel Pump pressure set to 6psi
    Driveline:
    1991 Th-700r4
    Front/Rear OEM springs
    B&M Rachet Shifter
    1991 10 bolt (7.625) with 28 spline and 3.23 LSD (but the LSD is worn out)
    Aluminium Drums and Aluminium rims with 275/60/15 in rear and 215/65/15 on the Front
    Edit: And Mines Toy ( Since B16EG posted his!!! LOL I almost forgot I owned it)
    2005 Suzuki Katana 600:
    Purchased: Sept 2007 with 8,900 mi. for $5,175 with helmet.
    Current Mileage : 15,896 mi. on 2008 July 10
    Engine:
    Bandit 1200 Header
    Ivans Jet Kit,
    Yoshimura RS-3,
    Factory Pro Advancer,
    NGK Iridium Spark Plugs
    Fumoto valve
    SMCO Magnet
    Oil Temp Sending Unit.
    Tune-up: Jan 2, 2008 Valves Adjusted
    OEM Air Filter
    New Brake Fluid
    Mobile 1 MX4T
    OEM Oil Filter
    Mar 02, 2008 Sync Carbs
    Brakes: EBC HH Pads
    Tranny/Drivetrain: Factory Pro Shift Detent Kit
    RK/Vortex Chain and Sprocket 14/50 & 520 conv.
    Suspension: Lowered Front 1 1/2" Rear 2"
    Tires: Front 120/70 ZR17 Michelin Pilot Power
    Rear 160/60 ZR17 Michelin Pilot Power
    Other Mods: Custom Paint Job( Flip-Flop red, with Pearl White Ghost Flames and Blue Pin Striping)( NO FAKE FLAMES NOR DECALS 0)
    Zero Gravity Dark Smoke Windshield,
    Clear Smoke Turnsignals,
    Intergrated Led Smoke Brake Light (Right now I have the OEM Brake/Signal install becuz I been riding on the highway more lately. I think the OEM setup is safer then the Intergrated IMHO),
    Mesh Mod,
    Pro Grips Red,
    Headlight Lamp Covers
    Painted Calipers
    Aluminium Bar End
    44 pc Led Kit.
    Frame Sliders
    __________________
    2006 GMC Sierra 1500
    1981 Oldsmobile Cutlass Supreme Brougham Diesel 5.7L Update May 29, 2010
    http://www.cardomain.com/ride/2961976/1
    Jet kit, 5 degree advancer,Yoshimura Slip-on, Vortex Sprockets F 14t(-1down) R 50t(+3up)
    Cobb County
    Quote Originally Posted by EJ1soSlo
    Fawk Chu..... and tell your boyfriend to jizz all in your face
    Ok, enough of the whoring. Post up your "profile" or go to the whoreslouge.
    is ARMY STRONG!! b16EG-HaTcH's Avatar
    Ft. Bragg
    ^^HERE I ARE !!!!
    i guess i am the "second in command" if Chris is the "high commander"
    MAIN RIDE:
    2004 Subaru Impreza WRX STi
    MODS:
    LULZ !!!
    TEIN S tech lowering springs
    Samco intercooler hoses
    more to come eventually.
    PROJECT:
    1992 Honda Civic DX hatch.
    MODS:
    b16 swap
    "GSR" tranny
    SKUNK2 Intake Manifold
    HASPORT mounts (if you would consider that a mod ???)
    DC sports short shifter
    HKS Hi-Power exhaust
    STAGE 3 weight reduction
    OPERATION DOUBLE WHAMMY NEAR COMPLETION !!!!
    (mine and Chris' car's together)
    TOY:
    2007 Honda CBR 600RR
    :stock:
    Scottish Scotsman's Avatar
    on the road to recovery
    Quote Originally Posted by Just_CHill
    fixed thread
    Ft. Bragg
    thank you^^
    Dec 2008
    Born n raised in the ATL
    Wow I didn't know you had a bike!!!!!
    Ft. Bragg
    yes mum i do has
    Rocket Man
    Dec 2008
    Griffin
    Quote Originally Posted by b16EG-HaTcH
    yes mum i do has
    U Fuker now I got to post mines
    __________________
    Ft. Bragg
    hahahaha should have posted it and ur aother cars to begin with
    Rocket Man
    Dec 2008
    Griffin
    I would post the Cutlass but I have no plans for it for a while, so for right now it is a back up car for when the Camaro is down.
    __________________
    Ft. Bragg
    ohhh...gotcha.
    Cobb County
    fixed thread
    Thanks!
    Southside
    Isn't this how Brad's car got stolen
    Cobb County
    No, Brad just always riced around the town anytime he was out. Just be careful, just like I always was!
    Ft. Bragg
    no brads car got stolen b/c someone saw it in his driveway and wanted it worse than he did.
    Southside
    this means i gotta take more pics..shizzzzzzzzzz
    1989 240sx Coupe LS1
    2005 Srt-4
    Dec 2008
    Quote Originally Posted by Axon360
    hahaha me too!!!
    Cobb County
    Well both of you need to get on it!!! Please...
    Southside
    I left my camera in montgomery...great =D it's gonna be awhile....I found a cool smiley so i figure i'll post for my own sake...
    2005 Srt-4
    Rocket Man
    Dec 2008
    Griffin
    You can use mine.. No excuse
    __________________
    Cobb County
    Quote Originally Posted by OldsTech
    Sweet! Good idea!
    Ft. Bragg
    I has got camera too if u ever actually come over, we can do some sweet shots of ur car.
    sol back on the road
    southside
    Bbat017
    Main Ride
    1996 Honda Civic Ex AKA The Dream
    Daily Driver
    lowering springs,headers,intake and exhaust
    The Project Car
    1993 Del Sol Si
    Factory for now
    Cobb County
    Very nice man!
    Southside
    Del Slo for now
    2005 Srt-4
    Cobb County
    *Pretends to be Jake*
    Hey, I'm Axon360
    Main Ride:
    Dodge SRT-4
    I have a motorcycle too, but I don't have pictures right now. Will post them up later........
    Aaaaaaaaaaaannnnnnnddd end scene.......
    Give me some pictures of your bike Jake!!!!
    Rocket Man
    Dec 2008
    Griffin
    LOL... Thats great. I might have a pic let me see...
    __________________
    Rocket Man
    Dec 2008
    Griffin
    This is jake bike. About a year ago. He has installed clear corners and ingrated tail light since these pics
    __________________
    Southside
    thanks to both my secretaries for posting my pics
    2005 Srt-4
    In High Definition!! DSGMach1's Avatar
    Sep 2008
    Quote Originally Posted by Bbat017
    Bbat017
    Main Ride
    Daily Driver
    .....with an "s" as in plural. Fucking ninja I knew you were bullshittin. What you got in there? Tree fitty? LS Juan?
    Cobb County
    Lol! Well I got bored and impatient!
