Hey I'm workin on a 2002 Kia Spectra. The ignition fouled on the column so its torn apart. The owner currently has the wiring off the back, and it starts it with a screw driver. I at first assumed the connection points on the ignition side of the harness were worn down and not making connection. However, with the wiring unhooked from the back of the ignition itself, its a sort of "Self Contained" unit where it has a slot for the ignition to be turned, with that off, the car is able to be started.
So he bought a new ignition assembly from Kia, when he picked it up he mentioned having a friend do it. When he said that the service guy told something about some sort of cable that is in the ignition.
There was only 2 things I could think of that would be cabled, that would be when the key is turned on it disengages the steering lock, or they were referring to the wiring harness itself.
Most of you know me, so I would appreciate legitimate answers, reps given of course.
Thanks
Edit: All I need to know is, am I going to run into problems with this "Cable" or is this not an issue.
