Results 1 to 37 of 37
Thread: B18A1 Ls engine and tranny
    aspiring racer
    Le Grand, Ia
    Default SOLD Please remove
    SOLD
    appreciate it NO CLUE
    The crack
    Nice
    good luck
    Get detail pics of the motor an tranny codes
    aspiring racer
    Le Grand, Ia
    I tried to get better ones but I stupidly tried polishing the block and now the tag doesn't read so well
    popping v-tekk
    Boosted 86 pick up!!! :)
    is that a cable tranny or a hydraulic????
    KINGZOFSOUTHTOWN
    Norcross
    how much mileage does this thing got?
    Quote Originally Posted by jdmeg_6
    apparently its cable.... hence why the lever thinger mabob looks different from a hydraulic one
    Banned 1991acura_ls's Avatar
    Chamblee
    nice thats wat i got on my DA THIS SHIT IS FAST
    aspiring racer
    Le Grand, Ia
    Quote Originally Posted by HMGDRFTER
    that I don't know if I had to guess, I'd say around 150k
    aspiring racer
    Le Grand, Ia
    haha thank you for the technical terms
    aspiring racer
    Le Grand, Ia
    sold tranny new price 350obo
    THAONLYDAW/SISEATS
    Winder
    that looks familiar
    aspiring racer
    Le Grand, Ia
    haha yeah man, I'm getting a toyota pickup and and 240sx in a month or two so civic been put on hold for a long while
    "IA's KWIK2"
    Default yeah..
    $200..lmk????
    aspiring racer
    Le Grand, Ia
    man that just hurts
    "IA's KWIK2"
    Default yeah..
    c'mon mann u get rid of diz kwik???lmk????
    aspiring racer
    Le Grand, Ia
    how about $300
    revolution big mac's Avatar
    lol at lowballers
    Unknown
    birchwood,tn
    pm me let me know if youll sell the intake
    BIRCHWOOD
    "IA's KWIK2"
    Default yeah..
    $250,last price,lmk??kwik2..
    EF Squad
    nice deal! should sell fast
    aspiring racer
    Le Grand, Ia
    don't really want to sell just the intake
    aspiring racer
    Le Grand, Ia
    I'm hoping it will too
    J.R
    Down South
    is the head gasket the only problem
    Certified Gearhead atlxhondax's Avatar
    Norcross, Georgia, United States
    100 buck for da head
    aspiring racer
    Le Grand, Ia
    yes other than you need a new distributor cap, couldn't hurt to change the spark plugs either
    With it needing a Headgasket and it has roughly 150K but not sure it could have 250K I suggest anyone that is buying this an knows it needs a headgasket to replace the rod an main bearings an piston rings....You go an get the head machined before installing a new headgasket is a must and when you do that it makes more compression an puts more strain on the bottom end and can cause it to start knocking ....So to make sure this will not happen take these steps
    Remove head and get it checked an decked an cleaned @ machine shop that knows what they are doing
    replace all main an rod bearings
    replace piston rings with OEM ones because they are good rings an you dont have to gap unlike some cheap aftermarket ones
    replace all gaskets an seals
    buy this time you can get a B20 from Tiger for 450 +shipping and be around the same price rebuilding this one
    350 for motor
    100 to have head shaved ,checked,cleaned.
    130 for headgasket set
    65 for main bearings
    45 rod bearings
    120 for oil pump
    28 for oil pan gasket
    40 for timing belt
    60 for water pump
    so decide wisely
    THAONLYDAW/SISEATS
    Winder
    350 for motor
    45 rod bearings
    120 for oil pump
    40 for timing belt
    60 for water pump
    so decide wisely
    idk if you have had a b20 but ive went threw 3 of them allready with just dd.. so 450+ shipping which comes to 589 plus 120 for an oil pump+ water pump and timing belt or you can put the ls together for that price and know everything is new and will flow smoothly ...so it really depends on how reliable you feel either option is......
    Quote Originally Posted by SX-MAN
    true, but most people on here has to pay someone to build it, you forgot about 500 for someone to rebuild it
    and a warranty if you buy from a JDM spot
    aspiring racer
    Le Grand, Ia
    350 for motor
    45 rod bearings
    120 for oil pump
    40 for timing belt
    60 for water pump
    so decide wisely
    or you could also consider that the head gasket is blown between the two cylinders and there is no contamination in the oil.
    So 100 for the machining and 130 for the gasket set, water pump up to you it was replaced recently, timing belt is always suggested but not needed
    so around 250 bucks and your 350 dollar motor would be pretty set.
    600 for a good running motor
    If you want replacement parts I'll help you get a discount on the parts you need also
    Quote Originally Posted by dope.didly
    HINT HINT why I posted that, Just because there isnt any oil in the anitfreeze doesnt mean you dont get the head checked an shaved. Any time you replace headgasket you ALWAYS shave the head it makes it seal right without any issues of warpage.Also you always replace the timing belt unless you the buyer knows 100% sure when that belt was bought and have proof other wise replace it...I would never repair this job half ass and if anyone did at my shop they would be FIRED..Do it right the first time and then everything will work out, do it half ass and it will cost you more at the end!
    BEST of luck
    J.R
    Down South
    PM'ed
    aspiring racer
    Le Grand, Ia
    need this stuff gone guys, want to get rid of the whole thing $325
    u still have it and does it run
    aspiring racer
    Le Grand, Ia
    currently and yes but recommend replace head gasket
    aspiring racer
    Le Grand, Ia
    selling today
    J.R
    Down South
    SOLD i got it
