Results 1 to 5 of 5
Thread: Binding
    Columbus, OH
    Default Binding
    Startin to get a lil irritated with this motor swap in the fukin cold guys.
    Again, what we have is a B18A and a transmission. The trans will not find its way onto the motor. We tried to install with the trans mounted in the car, now its out of the chassis and still wont mate to the motor.
    Is there any special method to this? I mean... I know its only 20 degrees, but I doubt temp has anything to do with it. Any lubs needed between the spline and the cupling? Cuz OMG this is starting to irritate us working on this simple part of the swap.
    And to add.. there is only about 1/2inch or less separating the motor from the tranny
    CHASE ->>>
    WHAT MATTERS
    Southside of The Jungle
    It takes a little time I put my on by myself and it was a bitch.Do you have the Dial pins however its spelled?
    EF Enthusiast jfrolang's Avatar
    far far away
    dial pins lol. They're dowel pins.
    You can use some lithium grease on the input shaft to help it slide into the clutch disc. Did you use an alignment tool when installing the clutch?
    Your mom's bed
    Quote Originally Posted by jfrolang
    x2
    Columbus, OH
    Nevermind, fixed it.
    CHASE ->>>
    WHAT MATTERS
