Results 1 to 17 of 17
Thread: Memory Card or Camera Issue?
    NANNERPUSS
    Dec 2003
    winder, GA
    Default Memory Card or Camera Issue?
    I am having a problem with my camera that I need a little advice with. I have a Nikon D40, and I am using external memory in the form of an SD card. When reviewing photos on the camera and zooming in to take a closer look, the camera seems to lose portions of the photo and blocks them out with "noise." It didn't bother me too much until I went to transfer those photos onto my computer, and each photo I attempted the aforementioned on is severely damaged. Could a damaged memory card cause something like this, or is my camera in need of a doctor visit?
    I do not have another memory card on me to test at the moment... just wondering if anyone has had an issue similar to this before.
    Can you post an example with it at 100 percent crop? IF you are losing portions of the photo in the same spot on all your photos it could be an issue with your image sensor.
    NANNERPUSS
    Dec 2003
    winder, GA
    Here are a couple shots. This is what it looks like when I upload it to the computer. It only does this to shots that I zoom in on on the camera. No adjustments other than resizing the photo.
    The white space and overlap are filled with noise when viewing on camera, but only when zooming in.
    Attached Thumbnails Attached Thumbnails -dsc_0003-jpg   -dsc_0006-jpg
    paint booth
    did you format you card for the d40? i had the noise problem before when i got my d40 and used a sd card from another camera. i formatted it for the d40 and it was fine.
    NANNERPUSS
    Dec 2003
    winder, GA
    Quote Originally Posted by boostedb16
    Yes. The card has been formatted. I originally thought that may have been the issue, so I removed my photos and reformatted the card. Still having the same issue.
    Hows the firmware on the D40? Is it up to date? That looks like a serious problem, I hope you resolve it.
    Roswell, GA / Georgia Tech
    Wow I've never seen anything like that before. I hope someone can shed some light on your problem.
    NANNERPUSS
    Dec 2003
    winder, GA
    Quote Originally Posted by 87 Turbo II
    Firmware is up to date....
    Quote Originally Posted by imbosile
    Me either... I'm hoping someone can help.
    paint booth
    have you contacted nikon?
    Senior Member Princess12's Avatar
    Bethlehem
    Not yet. We were hoping that with all the photographers on here that someone would know how to correct this, but I'm starting to figure out this is something beyond a "quick-fix." I will be contacting Nikon today.
    Everyone dies, not everyone lives...
    "Easy" is an adjective used to describe a woman who has the sexual morals of a man.
    want to buy a ps2?
    a little googling usually helps more than asking here:
    there is a reset button under the connector cover. (See page 118 in your manual.)
    or
    In your menu under Custom Setting Menu, choose Menu Reset
    Bethlehem
    Quote Originally Posted by james
    or
    Thanks for the advice, but we have already reset the menus on the camera.
    want to buy a ps2?
    Quote Originally Posted by Princess12
    ??? you aren't the OP....also, i provided 2 info things. one was a memory reset like you tried, the other was a hard reset. Did you try both?
    paint booth
    yea i would try this ^^^^^^
    NANNERPUSS
    Dec 2003
    winder, GA
    Princess is my wife, and yes, we have done hard resets on the camera.
    Jan 2003
    To isolate the problem to the either the camera or the card, go buy a cheap SD card and pop it in. If after properly formatted the problem looks the same.....you can narrow it back to the camera. If not, then it's a cheap fix by getting another card.
    Good luck.
    IA Member jennnay's Avatar
    I would definitely try replacing your memory card first, if that doesn't fix it then it may be your DG (digital imaging) board. It couldn't be your sensor or your shutter..i can say i've never seen something like that before
