Page 1 of 3 123 LastLast
Results 1 to 40 of 116
Thread: Build Done, Now For Upgrades!
    Cobb County
    Default Build Done, Now For Upgrades!
    Now that the engine broken in and most bugs are gone, it's time to upgrade! Sucks that I won't be here to do most of them on the account of me being deployed to Afghanistan. But it's all good, won't stop me from making it faster.
    Here's what I have so far:
    Skunk2 Pro 1 Cams
    RC 310cc or 440cc Injectors (Need to do research)
    Walbro 255 LPH Fuel Pump
    Skunk2 Carbon Composite (Mostly for bling factor lol)
    AEM Fuel Regulator
    Skunk2 Intake Manifold
    AEM Cold Air Intake w/Bypass
    2.5 Exhaust (Need to do research)
    GSR or B16 Tranny w/ LSD
    Any advice is welcome and definitely appreciated.
    EDIT:
    This is a LS/VTEC
    Now:180whp
    Shooting for: 200+ whp
    SPEC as of now:
    11.5:1 Pistons
    Eagle Rods
    Water and Oil Pump
    Ferrea Valves
    Blox Valvesprings and Retainers
    BatlGround Header
    Stock Injectors, Fuel Pump, B16 Cams, Intake Mani
    LS Tranny
    Magnaflow Exhaust 2.25
    lol @ my question.
    whats your hp goals
    Quote Originally Posted by Just_CHill
    Skunk2 Pro 1 Cams
    AEM Fuel Regulator
    If it doesn't have a nice ACT or spec stage 2 clutch, I'd put in one of those. I love the feel of a nice firm clutch. Also some good motor mounts, hasport or something like that.
    What motor is it? GSR?
    Southside of The Jungle
    Skunk2 Pro 1 Cams
    AEM Fuel Regulator
    Dnt know if I missed it but what motor is it?
    . eg mike's Avatar
    ga
    im with this guy
    Out the game again!!
    southside of the border
    ls vtec
    Soon!!
    Cobb County
    Lol, sorry about that. It is a LS/VTEC. I already have the hasport mounts.
    My hp goal is 200+ whp. Currently at 180whp.
    Southern Speed
    Macon
    What kind of head/intake manifold do you have? pistons? cams? I would recommend a 3" exhaust.... and also are you currently running a ls tranny?
    Southside
    Quote Originally Posted by DarKStaR
    B16 head, B16 intake manifold, B16 cams, and I think that the pistons are 11:1 high compression
    LS tranny besides being the only thing that was available and that he was at first going to boost it.
    Southern Speed
    Macon
    similar to what mine was...but i had higher compression. It really made 180whp? damn with b16 IM i only made 166, i would deff do a skunk2 intake manifold with 65mm tb, i saw some very nice gains with mine
    I'll second the skunk2 intake manifold and 65 or 68mm throttle body, I love my setup.
    Warner robins ,Ga
    dude throw some dual 50mm webers on that bit.
    DC5-R
    Gwinett
    I would have to disagree, with a stock b16 head meaning cams, valvetrain, etc. the best manifold is the stock manifold. Changing it out to a skunk2 would not be that much beneficial. With the skunk2, you lose all of your low-midrange with a little gain on top.
    And 62mm throttle body is the largest I would go with a stock b16 head.
    didn't see that this was a ls/v build, sorry about that, the o.p. didn't state what motor this was. I thought he had a complete b16 motor.
    Warner robins ,Ga
    Quote Originally Posted by IntegraXTR
    but b16 head is has the same design as the type r.
    lol. IMO, his setup would benefit from the IM and TB.
    My car will break the tires loose by punching it in first at any RPM... doesn't seem too much of a loss to me
    Southern Speed
    Macon
    I beg to differ.....Do i need to post my old vs new setup dyno sheet to prove this?
    DC5-R
    Gwinett
    Quote Originally Posted by xdavidscenex
    wrong, it is the same casting, not the same head.
    DC5-R
    Gwinett
    read my post carefully, I thought he had a complete b16 MOTOR.
    Southern Speed
    Macon
    Sorry i missed that part while i was stuffing my face....
    Cobb County
    Sorry about that. Specs are posted now.
    Yep, 180whp. Definitely going to try and order that intake mani either tonight or Thursday. Not sure about the tb though. Scotty from Mainstream said I should keep the stock one... But I'm definitely going to do some research on all of this.
    Sorry about that. The specs are up now though.
    Yes
    turbos
    I say get the GSR trans not as short as the b16 but still way shorter than the ls
    TOO BIG
    Southern Speed
    Macon
    Ok, took me a second to find where they moved this lol.
    I will pm you my graph and show you some differences..
    I would deff switch to a walbro. Injector wise, if you dont plan on spraying it in the future 310s should do the trick. And also like i said earlier do the intake manifold. The reason i stated a 65mm tb is because the Skunk2 Pro series intake manifold tb opening is 65mm so you are basically matching it instead of having 5mm of air hitting a "wall". Tranny wise either one will work, there will be a huge difference from the ls. Evan and myself run a b16 tranny, which will be better for the track. If you dont mind crusing around at about 3500-4000 then b16 is the way to go. GSR i would recommend if you do alot of highway driving. Although i still avg 30mpg with the b16. But from LS to gsr/b16 it will be night and day difference. The cam choice is really up to you, it really comes down to what you want out of the motor and is it reliable(assuming it is a daily driver) enough to drive a certain amount of miles a week. Im still in that stage of figuring out which ones to get, but im more than likely going with S2S2. Btw is the head ported any?
    is ARMY STRONG!! b16EG-HaTcH's Avatar
    Ft. Bragg
    ^^looking at ur newest numbers, urs a nd justchills car would be a good matchup....maybe I will bring his car out on the 31st
    Southern Speed
    Macon
    Mine is in an integra with all the works tho....
    Cobb County
    Quote Originally Posted by b16EG-HaTcH
    I would love to see a video of the run if you do sir!
    Ft. Bragg
    Weight diff. Is what u are referring to I guess?? Its all in good fun though, nah he will be the one to bring his car to the track. I will be in my car if u want to run on the 31st.
    Southern Speed
    Macon
    Yea i was referring to the weight, it weighs 2500 with me in it. Just chill will you not be there saturday?
    Southside
    Someone should run me motor for motor
    Cobb County
    Not going to make it. I'm going to be in Texas until April. FTL!!!
    Southern Speed
    Macon
    oh damn well that sucks
    Rocket Man
    Dec 2008
    Griffin
    JustChill, how much does your car weigh????
    __________________
    2006 GMC Sierra 1500
    1981 Oldsmobile Cutlass Supreme Brougham Diesel 5.7L Update May 29, 2010
    http://www.cardomain.com/ride/2961976/1
    2005 Suzuki Katana 600
    Jet kit, 5 degree advancer,Yoshimura Slip-on, Vortex Sprockets F 14t(-1down) R 50t(+3up)
    Cobb County
    Haven't got to weigh it with the new setup. I have heavier rims, a heavier engine, and lighter seats, so I would definitely like to see what it is now. But before it weighed 2085 w/o m in it.
    North Augusta, SC
    Chris, get stock dsm injectors. They are 440 I believe. They are a common upgrade on hondas. They will also be cheaper than buying "upgraded injectors" for the honda, just because they are stock. Just my .02, save ya some money and give you the same results.
    Back to being stock and slow
    FUK IT! bowdown201's Avatar
    Next Door
    Quote Originally Posted by EJ1soSlo
    Chris I have GSR tranny in mine. still short and good for a daily
    Southside
    Quote Originally Posted by bowdown201
    I see your
    and raise you lol
    See you at the track
    Cobb County
    Quote Originally Posted by Motivation
    Actually, that sounds like a damn good idea!
    Wish I had the moneys man!
    Southern Speed
    Macon
    I see your
    and raise you lol
    I see both of yours and raise you a :boobies:
    Cobb County
    Oh and the head is ported a little bit DarkStar.
    Next Door
    too bad my cars gonna :idb: hahaha jk......
    Chris I got one it just needs to be rebuilt I think, Hell it may not even be that bad it just need to be taken apart. you can get it for the low
    Southern Speed
    Macon
    Ahh, i was wondering where the little bit of extra power was coming from, cause from what ive seen stock head with b16/gsr cams max out around 175ish. I am sending you my graph as you read this.
