Results 1 to 14 of 14
Thread: Turbo for Ls.... PSI's????
    I am a BBOY
    Gainesville
    Default Turbo for Ls.... PSI's????
    IM thinking of going turbo with my stock Ls in my teg!!
    Im also putting racing pistons and cams?
    SO how much PSI would I be able to run without blowing up the motor?????
    11ty
    arp head studs and new OEM headgasket? rods?
    35lbs all day. you will be fine.
    ok u my friend are the perfect candidate for the search button.
    turbos
    TOO BIG
    LS Resurrection
    Fulton County, Union City
    10 psi
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    I'd say at least a good 45 and you dont even need to touch the pistons or cams just stock block head/studs
    No but seriously you will will need alot more than pistons and cams you need block and head work done to be able to push decent psi but they way it is stock without anything i would say like 8 or 9 comfortably
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by f22 a1
    What? Why are you yelling?
    What the hell are racing pistons? You going forged? Lower or Higher compression?
    -Ant.
    The Carbon Fibered R6
    LS Resurrection
    -Ant.
    most likely higher
    Senior Member G.C's Avatar
    Forgot
    Its not how much psi you should be running. Its how much power you want to be running.
    :idb:
    Quote Originally Posted by yunglaosta
    most likely higher
    If he goes for that 15:1, he can prob run an aggressive as hail cam and about 19-23psi...
    -Ant.
    LS Resurrection
    -Ant.
    yeah but i doubt that
    SwiperNoSwiping!!
    y'all r evil lol
    u remind me of a wigger !
