Results 1 to 5 of 5
Thread: I think the cable clutch needs an adjustment..?
    SwiperNoSwiping!!
    Default I think the cable clutch needs an adjustment..?
    My car is still driving with a cable clutch, but it has issues at times... Like for some reason, sometimes if i try to shift the engine from 6500+ rpms, the clutch will stick to the floor until the rpms drop just a tad. Basically thats my only issue with it, that and the fact that it doesnt allow me to switch gears as fast as i'd like to.
    I checked my clutch maybe back around last October and everything looked really good, the pressureplate and the disc had plenty of friction material left on it. So, im guessing maybe it just needs to be adjusted??
    u remind me of a wigger !
    ccw replicas
    kennesaw
    try adjusting the nut on the cable itself
    HF
    SwiperNoSwiping!!
    Quote Originally Posted by csmiths98AV6
    You talkin about the plastic thing ontop of the transmission?
    :police: NeWTRouBLeArMy's Avatar
    Rome, Georgia
    yes its the plastic nut on the cable where it connects to the transmission
    ccw replicas
    kennesaw
    you will see threads on the cable where it connects to the bracket that holds the cable onto the tranny, it will make the clutch stiffer or softer
    HF
