Thread: My DD needs tune up to pass emission
    E38 740i M fininfarina's Avatar
    Default My DD needs tune up to pass emission
    Anyone knows where I can get good price for tune up??
    Its 92 honda civic dx D15b
    I need change for spark plugs, wires, fuel & air filter
    not sure whether I need cat or not
    25/15 TEST 50/15 TEST
    Reading Allowed Reading Allowed
    HC ppm 85 153 PASS 162 159 FAIL
    CO % 0.17 0.86 PASS 1.42 0.89 FAIL
    NOx ppm 2806 1123 FAIL 2518 1242 FAIL
    please hit me up if you know some good place to change these
    ATLANTA
    <<<<<pm me
    RX7
    pm ed
    dude, i will bet you if you retard your ignition timing all the way. that shiit will pass first shot..
    thx
    Your mom's bed
    I highly doubt he will know how to retard his timing if he can even do something as simple as changing spark plugs, wires, and etc...
    Smyrna
    Quote Originally Posted by 00CelicaGT
    x2 if he is asking how to pass emissions, he probably can't retard the timing on his Civic. As per checking if the cat is okay, just unbolt it and check the inside to see if its intact. Or you could just find a testing place that will let you retake the test for free if it doesn't pass the first time you paid for it and keep fixing things until it passes.
    OK then how about this, take the 3 12mm bolts loose that hold the distributor to the head, rotate it towards the radiator, and then tighten it back down.
    1010011010 Atlblkz06's Avatar
    Hell
    NOx is through the roof - fromw hat I understand its caused by high cylinder temperatures.
    Either the AFR is out, EGR is not functioning, or maybe fuel pressure is low/ filter dirty?
    OR the CAT is bad.
    Either way - its gonna need fixing sooner or later.
    It'd make sense to start with a tune-up. You can go to autozone, get the parts and do it yourself or someone can do it for you.
