Results 1 to 29 of 29
Thread: Car picks up slow
    southside ATL
    Default Car picks up slow
    ok so my car picks up slow in first gear until about 4 secs around 2.5k rpm. it sounds like its sorta bogging and then it picks up and every other gear is perfect.. it drives perfect besides the fact that it picks up slow when i take off. could it be the tranny? or the clutch? someone told me it could be the forward clutch.. help?
    southside ATL
    no help? =(
    wheres tech5 and no mo honda when u need em!
    Dead or alive WANTED's Avatar
    You didn't by chance mess with your timing recently, did you? Something like that is usually a symptom of being off a tooth on you timing belt.
    If not, what else have you done recently?
    "Horsepower is no substitute for brains, fuckers."
    fuel pump/filter mayb
    southside ATL
    ^ hopefully because i get bad gas mileage also..
    southside ATL
    any other ideas?
    VTEC Killa!! 99' LuDe's Avatar
    Warner Robins,GA
    its sounds like a fuel problem, my car acts the same if i turn my fuel pressure to low.
    Either, timing,tune up, fuel filter(which I doubt that), stopped up cat!
    Check your tune up, timing first, BTW does it seems to be fine once you get up an moving along? or gets worse when it gets hot (car temp gauge is in the warm) Not the car running hot!
    Senior Member G.C's Avatar
    Forgot
    If the cat is clogged, won't it get worse as you speed up more?
    :idb:
    southside ATL
    its fine when it gets warm. it is throwing a code p0301 a misfire from cylinder 1. it seems to shake alot but im pretty sure thats the misfire.. could the misfire cause it?
    Warner Robins,GA
    yeah my buddys ls was misfiring and i sware to god it felt like his car was gonna fall apart, so that could def be it.
    Warner Robins,GA
    change your plugs
    southside ATL
    ^thnx. ima do a tune up
    Quote Originally Posted by j0natell0
    do plugs,wires,cap an rotor
    Stay Humble
    WV
    check your oxygen sensors man. same deal happened to me. it was real slow and hesitant until around 3k and picked up. and burned hella alot of gas. so check them. is your cel on?
    southside ATL
    Quote Originally Posted by chaseamundo
    yes
    Stay Humble
    WV
    yes
    if your running really rich then thats what i think it is.
    go to advance auto and have them run the comp on the
    ecu and see what they say...
    southside ATL
    it was the timing.. i fixed it. but now it throws aP0171 code System too Lean (Bank 1)
    what do i start first with this one?
    Stay Humble
    WV
    yo this could be a bad mas air flow sensor or a vacuum leak down past the sensor.try cleaning your maf sensor and check your hoses for any leaks.
    also check the fuel filter and make sure its clean
    LS Resurrection
    Fulton County, Union City
    yeahhh dats da way to go. my cousins 4 door ls had gsr plugs, wires, cap and rotors and it was misfiring like CRAZY!
    southside ATL
    i heard it could also be the o2 sensor.. i remember i saw the upstream one and it was bad. and i think my fuel filter needs to be changed also. ima check for any leaks today but i dont think i have any vacuum leaks.
    Stay Humble
    WV
    hell yea, check the 02 sensor for sure.....
    forest park
    i fixedd it fag
    southside ATL
    Quote Originally Posted by monkeyazzboi
    i fixedd it fag
    big ups to ur uncle too. haha
    southside ATL
    hey i got a 96 civic ex thats b20 swapped with a itr tranny. my CEL been's on and i checked it today and its throwing 6 codes!!!! wtf!!! i need to get my emissions done so i can get my tag asap!!
    the codes are
    p0170 Fuel Trim Malfunction (Bank 1)
    p0171 System Too Lean (Bank 1)
    p0301 Cylinder #1 Misfire Detected
    p1457 Leak in EVAP
    p1457 Leak in EVAP
    p1399 Multiple random misfire
    help me out importatlanta!!!
    Stay Humble
    WV
    ok, heres what you do, look them all up.....
    thats it man....
    then let us know what they say
    then we can further assist if needed
    forest park
    haha wtf..buy a new car
    the codes are
    p0170
    p0171
    p0301
    p1457
    p1457
    p1399
    southside ATL
    thats it man....
    haha dont think u understand what i meant. lemme edit last post
    southside ATL
    haha, aiite. ima buy a dirty DA
