Results 1 to 27 of 27
Thread: VTEC Issues
    South Side Georgia
    Default VTEC Issues
    ok im having issues with my vtec. i wired it but it still didn't pop vtec. i thought that i maybe wired it wrong so i disconnected the soleniod and the check engine light came on, so i know i wired it right. then i changed the soleniod and still no vtec. so i took off the whole pressure thingy and solenoid and cleaned them, and still no vtec. ppl ask me if my 02 sensor and speed sensor are connected or if its working and they are. im using a stock p28 and still no vtec so i switched to a chipped ecu and again no vtec... what the problem...
    resize pic
    needs temperature too
    North Augusta, SC
    How's your oil level?
    Back to being stock and slow
    South Side Georgia
    i let the motor warm enough to pop vtec and the oil level looks now normal
    resize pic
    インテグラ K20Z1's Avatar
    Buford
    check vtec fluid asap
    Dec 2008
    Northside
    make sure you have a knock sensor, im having the same issue. i need to get it chipped to eliminate knock sensor and tune it.
    Quote Originally Posted by *EJ2*Luis
    He is using a p28 which doesnt look for a knock sensor!
    sounds to me either wiring, or temp switch isnt hooked up
    yeah it might be the temp switch like stated above.
    i had the same problem in my car.
    SOUTHSIDE
    cherrios you have an ls motor thats why it dont work......lol
    South Side Georgia
    lol ^^ not. the chipped ecu doesnt pick up knock sensor, 02 sensor and one more i that i forgot, but its a chrome ecu that i bought from mr. kidd. but i do have some kinda plug unplugged below the knock sensor that i dont know what it is.. could that be it??
    resize pic
    is everything grounded okay?
    PG+K
    :noitacoL
    by my nieghbor.........
    man i had a similar problem as yours, but i had low oil pressure and it ending up being the head. g/l with this cuz it could be various things as you already know.
    South Side Georgia
    Quote Originally Posted by sc61equipped
    damn i doubt its my head though, but thanx but hope it aint it..
    resize pic
    VTEC Killa!! 99' LuDe's Avatar
    Warner Robins,GA
    probably oil pressure if it still isnt crossing over when its warm.
    about this far.
    umm i had a bad v-tec soleniod and it did not throw code.. you might want to check it.
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Warner Robins,GA
    what kinda motor is it??
    stock EK
    home
    Quote Originally Posted by gerardojdm
    lol ^^ not. the chipped ecu doesnt pick up knock sensor, 02 sensor and one more i that i forgot, but its a chrome ecu that i bought from mr. kidd. but i do have (some kinda plug unplugged below the knock sensor) that i dont know what it is.. could that be it??
    that the oil pressure sensor that is not hook up..you need to hook it up..it have a rubber cover on it with one single wire..
    South Side Georgia
    its a gsr i also plugged on thing that i was talking bout
    resize pic
    Quote Originally Posted by wrekonize
    LOL CHERRIOS!!!
    /Oo ___A___ oO\
    |=_/_______\_=|
    R Town Rida claybird's Avatar
    Coosa...Kinda Outside Rome GA
    damn mines doin the same thing and my vtec aint working...its embarassing getting beat when your boosted and no vtec...
    WANTED:
    A Girl That is DTF for a PhD
    Unknown
    My vtec engine r.pm. goes up and down when i starte it up when cold in the morning .Once the enine warms up the check lights comes on after the engine has been shaking . I need help find out what is wrong with car 95 Gsr. Ob1 system.
    oil pump can be the cause
    Quote Originally Posted by after7honda
    jump the code since your cel light is on.
    LS Resurrection
    Fulton County, Union City
    VTEC SOLENOID
    General Tech Hater
    Quote Originally Posted by yunglaosta
    VTEC SOLENOID
    watch out folks we got the honda technician of the year here.
    you need to check multiple things.. if everything is wired up correctly, i would get an oil pressure gauge that has a fitting to screw in place of your oil pressure sending unit on the back of the block to ensure youre getting proper oilpressure to the sending unit.... and make sure that sensor is plugged up, and plugged up good.
    if all that checks out then check the wiring for your ECT sensor, and make sure that sensor is good..
    LS Resurrection
    Quote Originally Posted by MidLifeCrisis
    sarcasm i suppose?
    IA Member bonb's Avatar
    Dec 2008
    Is it a factory gsr?or was is put together?
    PG+K
