Results 1 to 21 of 21
Thread: Kia Rio wont hold alignment...
    Default Kia Rio wont hold alignment...
    Got an 01 Rio, having issues keeping the alignment on it. Ive read lots of issues with this on the Rio and other shitty Kia's yet no fix for it. The car eats tires pretty bad, like 6K on a set of front tires before wire is showing
    Anyone ever messed with one of these cars and know why it keeps doing this? Ill have a print out of the before/after specs soon as I can get it on the rack.
    BMW 750iL
    DBlock
    tha ville
    whats a Kia?? .......1
    A POS?
    BMW 750iL
    ATLANTA
    u can check ur own aligment easy pm me ill explain it
    RX7
    Quote Originally Posted by blackyellrx7
    Its real easy when your a tech and have access to an alignment rack but Ill PM, please do tell me how to do without a rack. Im curious now. lol
    But the car just wont stay within spec. After a month of driving it needs an alignment again.
    BMW 750iL
    Oct 2003
    How are your bushings? Or struts?
    Havent looked at them, car has 140,XXX on it though. Its been this way since new according to the original owner and thats what I read online about these pieces of junk too.
    BMW 750iL
    Oct 2003
    Is the car from up north or anywhere there's salt water?
    No, been in GA since it was new. There is no play in anything though, like tie rods, bearings or ball joints.
    BMW 750iL
    Oct 2003
    Sometimes bushings can get soft to a point that the only way they move is under a load. Which would make since in your situation being that it's aligned oneday and out of align the next day. I would first take an impact socket and go over every bolt on the suspension to make sure nothing's shifting. Then I'd check the front subframe to make sure it's not shifting on you. Do the rear have it's own subframe?
    IDK about the rear, Ill have to look when I put it on the rack. Ill go over all the bolts and make sure everything is tight. You cant get the urethane bushing for this car because that was my first thought.
    BMW 750iL
    lmfao those cars are REAL POS. my mom had one like a 02 or 01, 3 transmissions, 4 sets of cv axles, 8 complete sets of tires, and one blown motor later she got rid of that pos.
    oh and a couple ecu's
    Yeah I know... its already had a trans last year. Needs both CV axles now, a starter and some other stuff but it runs and drives so whatever. Ill drive it until its dead.
    BMW 750iL
    2wheels move ur soul
    You didn't buy RedrumRacer's Mom's car, did ya?
    Newnan
    kias cant do anything right.
    learn to english
    the best thing to do is to set it on fire.
    Newnan
    or pee in it.. then set it on fire.
    learn to english
    JDM TYTE AnthonyF's Avatar
    We had one as a shop beater. I hated driving it. I am assuming it has to do with the high ride, and squishy suspension. Sell it and get a honda.
    -Ant.
    The Carbon Fibered R6
    -Ant.
    It runs and drives... why spend money I dont have to? Its not even worth anything if I sell it so Ill drive it as is until it dies.
    BMW 750iL
    is it the tie rods that keep losing alignment? Just use locktite or weld everything so it is locked in one spot.
    -Ant.
    Turbo-Wired
    East Cobb
    Was going to suggest that. Try using blue loctite first, if it still wiggles out then try red. Both of those ways you at least have an option of resetting it later. If you red-loctite it and it comes free, then I'd go ahead and set it and weld it in place. If it moves then, something has to be bent. O_o
