Results 1 to 14 of 14
Thread: high rev
    Default high rev
    ok i just put my stock injectors back in to see if i could get my car to run normal so i could go back to get it tuned if the cp checks out ok. well i put them in and now my car revs all the way over and want stop i need some help lol what could it be?
    ur injectors arent seating into the intake manifold causing crazy vac leak.
    im pretty sue there in good.if there not in good wouldnt gas be coming out
    Quote Originally Posted by kpowerhatch
    gas would come out if they arent in the fuel rail all the way. im talking about where the injector goes into the intake mani. there should be a fat square shaped grommet around all of them. make sure u didnt push one half way nto the intake itself when u put the injectors in. other than that, rechecked everything u took apart to put the injectors in.
    EE OG Revmaynard's Avatar
    Sup?
    Bozzio for president.
    ok thanks bro. btw i have a edelbrock intake mani and one of the screws that go thru the fuel rail broke could that cause it do leak.im not sure if i can get it out and rescrew a new one on so i can put a bolt on the end of th fuel rail
    if the screw broke off in the hole but didnt leave a hole (so air can get in) that wont cause it. but it wont allow ur fuel rail and injectors to seat properly. more than likely the pressure of the fuel will push the closest injectors out of the rail. those studs arent usuallt tapped all the way through to the inside of the mani itself. not usually.
    so there easy to get out
    depending on if u have enough left to grab with pliers or if u need an extractor set. i had to drill out all of my exhaust studs bc they kept breaking so if its not easy, it will be. lol!!!
    oh its enough to grip where could i find another stud at?
    home depot or any parts store. i think the thread pitch is 8mmx1.25 but im not 100 percent sure. u can use a bolt if u got one. i used like a water pump bolt b4. but i dnt know if the jg has the same honda thread pitch bc im not ballin enough to have a jg. lol!!!
    lol... thanks bro i ll see what i can find
    maybe a stuck gas pedal! or TB cable too tight! 8D try pulling on it! and maybe you 4got some o rings that goes inplace where the injectors soppose to be in! and possible the filters inside the injectors are not there no more! cracked! injector filter. 8D just thought i throw it out, but shittt i need to fix my problems myself haha
    /Oo ___A___ oO\
    |=_/_______\_=|
    Southside Ridin HATCH
    sounds like a leak!!!!
