Results 1 to 40 of 47
Thread: 9:1 cp pistons
    Default 9:1 cp pistons
    ok i just went to get my car tiuned and we ran into a tone of problems.he told me my cp was to low for the 9:1 pistons. 1st cylinder was 10 2nd&3rd 110 4th 140 is that normal.it has a fully built head crower stage 3 cams
    anyone lol
    Quote Originally Posted by kpowerhatch
    hold on #1 had 10 psi. for the most part u want a 10% variation in pressure max.
    1010011010 Atlblkz06's Avatar
    Hell
    I think you meant 100. Even 110 is low - something is up.
    Oct 2003
    Thats pretty low atleast 180psi ... did you do a proper valve lash adjustment with stg3 cams? DOes teh car smoke on take off?
    Hell
    180 for a high CR N/A motor. 140 is about right for 9:1 CR I think.
    02 WRX patrick4588's Avatar
    warner robins
    Quote Originally Posted by Atlblkz06
    no. 9:1 should be around 160-180. a stock gsr has 220-240 if its healthy
    GCO Member
    NRA Member
    blank
    nowhere
    expected for where you got that motor
    i got the motor from andrew which he said someone built so im not sure if its a good motor or not.he suspposed to come check it out tomorrow and if its not gonna check out i guess where gonna go to court over this unless he wants to fix it like this weekend. i gotta have a car before i go back to college.but it was 140 110 110 140. itt has stage 3 cams in it but im not sure if the motor is even done right because everybody is sayin he is a bad person now
    lol court so quick. u said u had the head off already correct.
    owned!! Warranty void.
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    x2... something is wrong bro
    Default hey
    no he sent me a picture with the head off
    i dont know who said i took the head off but i never took he head off.for some reason he had to put a timing belt on when he got here.im not sayin he screwed me but he gonna try and come up tomorrow and fix it
    140 on one wheel
    columbus, ga
    looks like no turbo lol!!
    what you mean looks like no turbo
    my new setup
    post #17
    oh we took it apart i do know its built like he said it was
    we took the oil pan off not the head he offered to come take it apart to show me whats in it
    thank u for clearing that up for me
    that was my bad bro
    i wasn't trying to make you look like a lair or anything just was confused.
    lol i understand i should of said.but if he comes thru and fix the engine tomorrow everything will be cleared.but its just so much from ppl thats makin me think even more
    hey someone lock this thread andrew came and fixed the engine it runs fine now time to go back and get it tuned
    what was wrong with it?
    atleast he got it working right.
    Default hey
    bad tb gasket,one of my intake mani fitting fell out,starter wasnt ground to good and etc....
    villa rica, ga
    none of that should have anything to do with your cp but gl with it
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    im not sure if the batt was gettin off enough power because the batt was dyin
    im not sure if the batt was gettin enough power because the batt was dyin
    I'm quite sure that makes the least amount of sense I've ever heard.
    something is wrong with this picture.
    Hell
    220PSI = 15:1 compression. How do you get that from a 10:1 compression motor? Heat is the only factor I can think of that can affect pressure so drastically.
    Oct 2003
    these are hondas we make 180-240psi and less than 220hp LOL
    but seriously
    Hell
    Quote Originally Posted by Annihilation
    but seriously
    None of these numbers are HP. 220PSI pressure.
    Senior Member G.C's Avatar
    Forgot
    How did all those things you listed fix your Compression.?
    :idb:
    well i talked to scotty he told me to let oil sit in the cylinders to built the compression back up.the 1000cc injectors must of washed the rings
    Oct 2003
    this is how we get to 11:1 + comp ratios
    B Series Compression Ratio's for different setups
    140 on one wheel
    columbus, ga
    looks like no boost for you right now...lol what do you think it means!
    why you say that it runs now
    140 on one wheel
    columbus, ga
    tha hell you talking about my old 10:1 gsr motor had 240 all across the board and my 10:8:1 h22 had 270
