Results 1 to 29 of 29
Thread: question bout syncronizers
    griffin ga
    Default question bout syncronizers
    working on a b18 ls transmission i was replacing one of the brass sync rings cause the one that was in there was worn bad on the inside but the teeth around the outside of the one that was in there are the same size as the new one but the new ones teeth are deeper seems to fit fine just wana know if its gona work right o an the new sync ring is out of another integra trans but not sure what year minds a 94
    griffin ga
    anybody?
    step sticky stephen's Avatar
    personally, i'd suggest buying one that's SPECIFICALLY meant for your transmission.
    i don't really understand how the teeth can be deeper, but the ring still be the same exact size. that doesn't really make sense...that's why i'd just get the exact same ring that belongs. it'll save you a headache.
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Quote Originally Posted by stephen
    X2 Yeah you dont want to make a costly mistake
    griffin ga
    well its hard to explain the teeth are deeper from top to bottom but same length protruding out its on the top of the mainshaft so if it doesn't work itll be easy to replace
    Quote Originally Posted by 2.25teg
    there's 3 problems with that though....
    if the teeth are deeper, but the rings have the same outside diameter, then the inside diameter is not the same.
    the teeth are designed to "mesh" together. if one set is longer than the other...then the rings won't mesh.
    different rings are also made from different materials. there's NO WAY for you to know whether the ring you have is made from the exact same material as the old one (especially considering you don't even know what it's out of).
    regardless...i still don't think you'll listen, and probably put it on there anyway. if it works, great...but i just wouldn't do it. sure it might be "easy" for you to do...but it's a waste of time to have to tear into the tranny again. if you don't care, then go for it.
    griffin ga
    the teeth arnt any longer their deeper into the center lock from top to bottom an it seems to go in a out just gear as easily as the others
    Oct 2008
    You should just try and find one for cheap thats meant for you car
    sounds to me you dont know what your doing an shouldnt be trying to fix this, I will put a stickie in my box so I remember not to buy a tranny from you
    North Augusta, SC
    lulz....
    Hey Josh, how did the stang run at the track in FL.?
    Back to being stock and slow
    didnt make didnt have it running in time, I got it running and I might have a buyer tonight ,
    Quote Originally Posted by Motivation
    lulz....
    North Augusta, SC
    buyer? No, I think you are supposed to give me the car. lol... Well congrats on getting it running.
    Yeah I drove it around Mcdonough last night runs super great! but this guy really wants it and Ill be making a shltt load off of it
    North Augusta, SC
    Awesome man. Can never complain about that.
    griffin ga
    I've rebuilt one before but this ones being rebuilt out some parts i had layin around lol but if no one knows if it`ll work just have to try it to find out
    Oct 2008
    They are offtopic
    and you are?
    Quote Originally Posted by STRteg
    They are offtopic
    Oct 2008
    and you are?
    I'm the guy that goes in when you leave :idb:
    griffin ga
    Your also the guy that gets Repped in every thread too
    Oct 2008
    Only by haters like you and i get repped cause i get caught leavin too much
    griffin ga
    They are offtopic
    very much so an no answers to my question either
    1st of all!
    If you use the right parts you will not have this issue!
    2nd of all if you knew what you was doing you would know the right answer too
    but its all good...Buy the right parts to make it work the first time, dont try an jegga Boo it !
    griffin ga
    not gona waste 200 bucks on a sync if a got one laying around just a waste of money if tha one i got will work worst case it sticks/grinds fifth gear will know if itll work by tomorow or thursday
    griffin ga
    Will deffinatly do.but gona give this a try it's in the car now just got a few things to finish up i did find out that ring was out a 98 so hopefully we'll know sometime this evening If it's gona work
    Oct 2008
    Yeah man lmk
    griffin ga
    drove it today shiftin like brand new
    North Augusta, SC
    Hey man, You gonna be around next Wednesday? I will have my clutch close to broke in by then so I'll be down there.
    griffin ga
    Yeah let me know
