Results 1 to 13 of 13
Thread: N/A build... opinions please
    Jam Spec!!
    Oct 2003
    Grayson, Ga
    Default N/A build... opinions please
    I've built a couple boosted motors but a friend wants me to buil him a N/A motor. Since this is new territory for me I figured I'd get some opinions.
    I've read Mike's sticky thread above and I'll be using some of his recommendations.
    One of my biggest problems is that the highest grade of Gas we get here (jamaica) is 90 so I don't want to run into the problem of too high a compression with not enough fuel.
    ANyway... here is what I have in mind:
    Gsr block (81mm)
    Itr rods w/ arp bolts
    Pr3 pistons
    Jdm Itr head
    sk2/blox IM
    310's
    walbro 255
    Not sure what header just yet
    Access to a good maching shop to get the head worked on is pretty much impossible unless I send it to te states... and he working on a budget
    There u have it... opinions would be greatly appreciated. Oh, shooting for around 200whp
    Southside of The Jungle
    Smaller fuel pump alot of people say 255 are overboard, Just get Oem honda one
    dont listen to him ^^^^^
    there is no such thing as too big a fuel pump FYI. GO with the walbro 255, its cheap, and its more than what you need. Id never trust a old fuel pump on my freshly built motor.
    Headwork isnt really needed with the build you have laid out, you prob wont see 200whp on a dynojet. very FEW OEM builds make that kind of power.
    you are going to need camshafts, id prob go with Skunk2 PRO1s if it were my car, or BC3+ if i didnt want to change valvetrain.
    Header wise, any of the 3 i sell will work, id recommend the RMF NArrow Replica as it makes the most power, then the Hytech Replica
    Certified Gearhead jdmda9's Avatar
    X2!
    shhh...
    vtec game scArY. . !
    I didnt say use all I said was simple get oem honda one I forgot this is IA ,So let me give you instructions Go to honda Dealer
    Untouchable Tank's Avatar
    Honolulu
    Dude on NA honda's Mike knows his shit he didnt make that monster Rex from nothing bro, and theres nothing wrong with upgrading fuel pumps better rich on fuel then have no fuel at all...
    no, you assume wrong. Im eant he should replace it no matter what
    why buy a NEW OEM pump when you can get a walbro for $85 shipped.
    why replace a stock pump that is only capable of 150lph or less for MORE MONEY.
    Tell me why a 255 fuel pump is TOO BIG and why its a problem....
    I dont know alot of people told me dont use them for allmotor setups.Alot of people say use 195lph I didnt know Oem Honda ones were 150lph I thought they were 195lph.Well you live and learn
    Quote Originally Posted by Tank
    I was just stating my opinion.
    Jam Spec!!
    Oct 2003
    Grayson, Ga
    ok mike... if u wanted to build a 200+ whp NA setup what would u do? forged internals are also an option
    me i would just get it sleeve to a 2.0l and do some head work and call it a day..but there's alot of 1.8l that make a little over 200..check on honda-tech..there's way more source and a lot more people that can help you out..
    Quote Originally Posted by wespirl
    sleeve me please?
    monroe
    on my car right now i have a GSR block bored out to 82 mm and they are pr3 pistons on GSR rods stock GSR crank balanced ACL race bearings, dual springs titanium retainers comp cams stage two 63402a-2 aem cam gears 440cc injectors holley 255 feul pump feul pressure regulator, some crap headers and thats it shit runs good but not done with the toon i am hoping to hit close to 2 if not 2 but i want to buy mr kidds new header he made but cant afford it!!
    sleeve me please?
    monroe
    all a feul pump does is increase your flow go ahead and get the big one so if you make any changes later it dont mattter when you get it tuned he will set all that straight!!
    everywhere & nowhere
    Why does every1 build "OEM" N/A motors (pistons/intake mani's)? I don't get it - LOL. Get some GREZ 12.0 - hell even some Probes if you are tryna keep it a budget build. Do NOT skimp on the header b/c w/ the head you are using you are gonna need a serious header to compensate for the "stockish" head you will be running.
    Secondly... in PR you are only 1 octane below what the west coast gets outta the pump (Cali) -- and there are some serious pump-gas builds there. 90 octane is hardly low enough to worry about (based on the build list you have stated) IMO. This build so SO mild that I hope the car is going on a diet and getting a lighter rotating assembly (ie. SCAT rods are lighter and stronger than the ITRs) and LSD.
