Results 1 to 17 of 17
Thread: all motor ls burning a lot of oil
    Default all motor ls burning a lot of oil
    my car is losing alot of oil no spots underneath car when siting. smokes a little black which is rich. but i cant figure out where all my oil is going. im losing about .5 every 500 miles
    it is untuned
    mods all new
    oem pr3 pistons
    all oem gaskets seals and rings
    crower 404 cams
    crower springs and retainers
    ported head
    unorthadox pulley
    act prolite flywheel
    so is this normal?
    Senior Member jfman's Avatar
    Inspect the plugs, check the compression and come back to tell your findings.
    check cams seal, crank seals, cam plug, take your exhaust header off and check the ports see if its wet ( if it is then your valve stem seal). And who ported the head? Might also want to get the head inspected for cracks.
    Southside of The Jungle
    My car used to smoke alot at high rpms black smoke.I believe it had somthing to do with the head.
    yeah i had the head inspected and had new valve stem seal put in it suposidly. before the build. but i cant figure out where it is going it does smoke at higher rpms. but i dont think it should lose this much oil.
    DUH-KYOO-LUHHH
    if it smokes at higher rpms, its most likely head-related as opposed to rings. 1/2qt per 500 miles isnt THAT bad though.
    Oct 2008
    Thats weird you can't find any leaks anywhere.
    Quote Originally Posted by meengreenPGT
    Its not leaking its burning it!
    Either in the head or block
    turbos
    do a leak down
    im calling stem seals of rings
    TOO BIG
    hey how much hp did u make?
    Woodstock
    mine was caused by blown valve seals
    Columbus
    Quote Originally Posted by Thighs
    true...im loosing about 1/2qt every 2-3 days. buring and leaking...bad part is someone "rebuilt" it...
    and agreed..check your plugs. do you have oil on the tips of the spark plugs?
    Sleeper... I <3 my EF's Avatar
    Valdosta...
    Mine burns a lil oil in the upper rpm range. My solution was to stop ragging the sh*t out of it everyday......
    Hwy 315
    seems to be almost typical of a built LS to drink a little oil.
    I know it's not correct for it to do it, just typical.
    Mine does as well, not as badly though. There's good advice in this thread, pay attention to it.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
