Results 1 to 24 of 24
Thread: Leaking Transmission.. help
    Norcross
    Default Leaking Transmission.. help
    my old car has a leaking transmission. i took a look at it today and one of the bolts that goes through the tranny was tightened too much or something and there is a small crack starting from the hole. anyone know of a shop where i can get this welded or any better options? i really dont want to get a new transmision if that can be avoided. btw the car is automatic. reps for help
    span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
    JB Weld ftw.
    id say TIG weld ftw.
    Norcross
    yea a freind told me to get it TIG welded? how much do u think this would cost?? the crack is less than in inch long
    Quote Originally Posted by j0nbunklah0m
    well if it is easy to get to, not to much. hard to get to, a lil more. the also have to make sure that the area was clean.
    Telling ya, JB weld or some epoxy, if it's just a hairline crack or something. Cheap and holds fine.
    Oct 2003
    What kind of car are you working with?
    Norcross
    its a 96 civic. the crack is relatively easy to get to and is very small yet trans fluid drips from there pretty quickly
    Southside
    QFT you'll be amazed of how good it works, but that only if you Read/Follow the direction.
    Dont use the pack that uses the red tube an black tube JB weld it takes to long to dry! like 15hours-24 hours to cure
    Use the pack that includes 2 tubes one orange,an one blue tube this pack will dry in about 45mins cured!
    Also clean the sopt to be JB welded an clean an use some Sand paper or scotch pad to clean an it will make it stick alot better
    qft
    drill 2 holes besides the crack, stick in 2 screws and a rubberband that shit together
    Norcross
    aite u try that an leme kno how it goes.. thx for the replies and im gona try JB weld tomrow i'll let u guys know how it goes
    You can not weld that crack with any type of fluid leaking out. You'll have to take the trans out, turn it upside down, and then clean the crack so no oil residue is anywhere near it. When you heat it during a weld, it will draw the fluid out of the crack contaminating the weld.
    As said, JB weld.
    as long as he wipes it out clean an dry it , and the fluid settles he will be fine i done this to honda/acura tranny about
    1,999,289.908.09 times
    Quote Originally Posted by Init2winit
    As said, JB weld.
    try my method man
    You got to be the most stupidest person I have ever seen post on IA
    Quote Originally Posted by Benefit
    barrow county
    super glue it?
    Norcross
    aite, well i jus JB welded it today. i actually used JB WELD KWIK or sumthing like that, the suggested orange/blue bottle i'll let u guys know if it holds or not. thanks for advice
    ATLANTA
    jb weld will do the trick just make sure the area is really clean and dry before u put the jb weld on
    ATLANTA
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    oh snaps burn!
    griffin ga
    if that doesnt work you can use an aluminim rod with a stick if you can keep it dry but thats gona be hard
