Thread: 1999.5 2.0 Jetta GLS Engine
    'Round These Parts
    Default 1999.5 2.0 Jetta GLS Engine
    Anyone know of a good place where I can get a low mileage one with a warranty? I need one for a 1999.5 GLS 5 Speed
    Are 1999.5 - 2005 all the same thing?
    EDUCATE ME PLEASE VW Posse!
    Leisa and S. 4 Life NM?
    griffin ga
    if you can find someone that works at lkq they should be able to hook you up
    'Round These Parts
    i've gotten a lot of engines from there.
    Are they all the same '99.5 - '05?
    'Round These Parts
    Anyone else with info...need to make a move A.S.A.P
    No they are not all the same, and yours is probably the AEG
    1. The AEG is the only engine in the MK4 2.0 lineup that still has the throttle-by-cable system. All later engines use the Drive-By-Wire system. Thus, EPC is not available for the AEG engine code.
    2. The most interesting engine code seems to be BBW. It has different torque and hp curves and it has 3 (that's right, three) oxygen sensors! It is also the only one that does not have a secondary air pump
    'Round These Parts
    Thanks for the info. i assume the 2.0 long blocks (without intake exhaust manifolds are the same.)
    I'll be picking up an engine soon!
