Thread: Necessary to Drain Coolant from Block?
    EM1 Crew Member
    Default Necessary to Drain Coolant from Block?
    I'm replacing a bad radiator as well as all the hoses and thermostat.
    The service manual recommends to drain the coolant not only from the radiator but from the block as well.
    Is this necessary? if so based on the diagram the bolt is located on the left side of the header...looks like its behind the heat shield...
    how would i route the fluid out from the hole if i have to drain the block
    1999 Honda Civic EM1 FBP (Current)
    1999 Honda Civic Ex VSM (sold)
    1997 Honda Civic DX MR (Sold)
    H-T EM1 Crew Member
    Privateer Racing!!
    Duluth,Ga
    Quote Originally Posted by Andy099
    NOpe, i never drain it!!!
    Norcross
    i never drain mine either
    Privateer Racing!!
    Duluth,Ga
    Too drain the block , their is a BIG hex key on the front of block, loosen that and all the coolant will come out!!
    Northwest Georgia
    just do it old fashioned way and start disconnecting stuff and let the water do its thing lol.
    EM1 Crew Member
    lol yea that is what i plain on doing..
    i bought a bottle of the prestone radiator flush that you mix with water to flush out the system..then do it again with just water
    after all that then pour in Honda Coolant
    H-T EM1 Crew Member
    i dont drain it unless it had a blown head gasket and the oil and coolant mixed.
