Results 1 to 23 of 23
Thread: Turns Over No Start
    Default Turns Over No Start
    I got a 95 honda civic. when i turn the key over i dont hear my fuel pump prime. when the key is in the on position the eng light does not come on but when i start to turn the key the light starts to come on very low.
    i checked all the fuses and grounds seem to be ok. I dont hear a click from the main relay. should i hear a click from it? if so could this be my problem?
    Scottish Scotsman's Avatar
    on the road to recovery
    sounds like battery is low , check that first
    main relay ecu bad pump
    can you get one of those at autozone ,lol
    is better than you..
    Somewhere you're not
    you can get the main relay and fuel pump but i doubt an ecu
    battery got low after trying to get it started but had it on jumper cables so its not the battery.
    should the main relay click when turn the key over?
    Quote Originally Posted by Krappy
    lol , i was commentin on how he posted it , kinda sounded like one part
    back to OP
    if you dont hear the pump kick on , i would check the relay then check the f. pump
    griffin ga
    have you checked to see if you have fire an if so loosen the banjo bolt on fuel rail an See if you have has comin out an have you done any thing with the distributor lately
    Hamilton, GA
    main relay
    fuses
    grounds
    i checked and dont have any fire. i have replaced the coil and button and cap and still no fire
    Module in the DIZZY
    Module in the DIZZY
    what is that?
    ne other help?
    M.T.4.L. noridetoolow's Avatar
    Columbus, GA
    YES.....you should hear the main relay click when you turn on the ignition...once if not twice...if you have to, stick your head under the dash and slowly turn the ignition on. If that main relay is out the car will turn over ALL DAY and never start. If you can wait....get you a main relay ( or a few of them to be safe ) from the junk yard...
    2000 EM1
    1998 Tacoma
    ...bagged.....in the process of a body drop
    griffin ga
    that wont cause it not to fire its got to be in distribtor maby wires but not likely maby 180 off
    but as i stated in the OP that my fuel pump also stopped priming also and the dizzy would have ne thing to do with the fuel pump
    Module in the DIZZY
    I wish I had 100 of these laying around that were good... lol they always go out... Just replaced one 5 min ago, wigged out in higher rpms..
    got my pm?
    Quote Originally Posted by stock05evo8
    got my pm?
    yes. replied
    Southside of The Jungle
    check to see if you have spark if you dont may be coil pack.
    already replace the coil and i still dont have spark
