Results 1 to 11 of 11
Thread: swapped SR20 not starting..
    Default swapped SR20 not starting..
    Buddy just got done swapping his SR20 into his s13. He sent the harness to a professional for re-wiring. The car will roll over but not crank.
    He thinks its not getting fuel..?
    • He says he can hear the fuel pump whine/click when key turned
    • Spark plugs dont smell like gas and look good still.(ngk)
    any helpful advice to point in the right direction to check out?
    Thanks
    Is the car getting fuel? Just because you can hear the pump doesn't mean the engines getting fuel.
    ^^ he dosnt think its getting fuel last sentence before the bullets.
    Did he mix up the feed/return line?
    ^thats what Madhavi told him.hes going to run out and get another hose and try it..
    -You get my PM on 6ga?
    ya i replied
    Sep 2008
    lithonia
    if you can get your hands on a fuel pressure gauge, use it. it may not be getting spark at the distributor. that was a problem i had when i did my swap.
    Slimm
    make sure the CAS is stabbed right
    He swapped the lines and still nothing.
    Hiram ga
    if you not getting spark you may be missing the igniter box
    He has the ignitor box hooked up..the person that did the harness conversion also sent another type chip with it;but it dosnt match any plugs on the harness..
