Results 1 to 19 of 19
Thread: Hopefully geting my crx tuned in a week or two.
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Default Hopefully geting my crx tuned in a week or two.
    I'm going over my car before I trailer it 1.5+/- hours to a tuner. I want to go over the car and make sure I don't waste the trip.
    What would be the best plugs to run? I'm thinking NGK bk7re but don't now.
    Any advice would be great. Thanks
    My setup
    Z6 stock bottom and P&P head.
    65mm TB with port patched intake manifold
    stock ignition
    DSM 450cc blue tops
    GM 3bar map (still have the stock map hooked up but the 3bar is wired up but not pluged in)
    td04 14B with stock 7psi wastegate
    HF crx manifold with td04 adapter
    front mount intercooler
    p28 ecu chipped with chrome pro
    any advice would be great. thanks
    Quote Originally Posted by Mad Mike
    My setup
    stock ignition
    DSM 450cc blue tops
    The 7's will be fine for that much boost.1st thing is make sure ALL fluid leaks are fixed cause no tuners wants you dripping shit all over his/her dyno.2nd BOOST LEAKS.Fix all of them before you go.3rd do a comp test just incase.That should be it.
    Gainesville
    No leaks right now boost or fluids. Now I just got to find someplace that that has the NGK in stock.
    thanks
    Advance Auto.
    Gainesville
    Ok thanks for the help
    Privateer Racing!!
    Duluth,Ga
    Make sure u have a boost controller, eighter manual or electronic
    Gainesville
    what for I'm only going to run 7 psi?
    So that way you can go ahead and tune up to your highest goal psi. If not you'll have to get retuned if you ever do turn the boost up.
    Gainesville
    it good at 7psi right now I'm going to start building another motor in a few months. Then the boost will go up.
    Gainesville
    Well it will be getting tuned on the 7th by mainstream performance. I can't wait its been so long since I've driven it.
    Made in BRASIL junior_tm's Avatar
    Brasil
    cool let me know your numbers because i'm finishing a setup almost like yours and will be running the same psi thanks
    ToTaLMaDNe$$
    Yeah we roll and we ride
    In control, we don't stop
    We gonna glow where we drive
    Let you know we on top
    02 WRX patrick4588's Avatar
    warner robins
    psi doesnt mean much, why not set a hp level to shoot for?
    GCO Member
    NRA Member
    Gainesville
    Its a stock motor other than the 65mm TB and maybe a port and polish. I'm going to build a motor to make power later on and I don't expect this motor to last vary long anyway.
    Don Mon SiRed94's Avatar
    Morrow 30260
    If in any way possible, ditch the HF manifold.
    Gainesville
    I started with a ramhorn style but it put the turbo out to far. This was a budget build so I already had the manifold. I plan on using a good one on my next motor.
    We carry Bkr7e's in stock, also, if you get them make sure they are gapped properly, check your timing out,check your fluid level, make sure there are no cel's etc... It will make for a more efficient and quick session..
    Gainesville
    anyone know what auto parts store sells NGK wires. I need to know witch ones sell the wires so I don't drive around wasting gas. thanks
    call around...most can order them and get them w/in a day or 2. if not just get the stock honda ones from honda.
    Gainesville
    ok thanks
