Results 1 to 5 of 5
Thread: 92 civic dimmer switch bypass
    Norcross
    Default 92 civic dimmer switch bypass
    I have a 92 civic and my dimmer switch died on me.. and everyone is over pricing them.. so is there anyway to bypass it? i was told to connect the sold red to the black wire? just want to be sure before i do it.. reps for help
    span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
    Norcross
    anything?
    is better than you..
    Somewhere you're not
    get a multimeter out and check for yourself...shouldnt take more than 2 minutes to figure out
    chill six7teen's Avatar
    Columbus
    yeah, i had to do this in mine as well.. just pull out the dimmer swith and unplug it... you can cut it if you want to, but then its hard to get it working again if you ever want to use it again..
    there will be three wires, a Solid Black, a Solid Red, and a Red/Black. You want to connect the Solid Red and the Solid Black. This will turn your cluster lights on when your light switch is on! They will be on full bright, and you wont be able to dim them, but they will work.. if this doesnt work, there is some wiring problem... there is no need to plug it back into the dimmer switch, just make sure there are no exposed wires.. then you can just slide the dimmer switch back into place, and nobody will know
    go to pullapart, pretty sure they have it and it's not over price.
