Results 1 to 14 of 14
Thread: Vtec not working all the time?Help
    DEAD DUCK 1slowep3's Avatar
    Default Vtec not working all the time?Help
    I have a 94 prelude with a jdm h22a motor in it.The vtec works sporaticaly(sp).When the car is cold and the code 21 is cleared the solonoid engages but when it warms up and I stop the car the cel comes on.it only happens when the car stops.I drove from Atl. to Macon without the cel code 21 comeing on but when I stopped at my exit the cel came on.i have tested the solonoid the two ways I know how.I have applied 12v to it and it opperated ans I tested the ohms of the solonoid and got 15 ohms.And from what I read it should be between 14 and 30.I have oil pressure 25 at idle and 75 at 5k.that is the oil pressure at the oil sensor.I havent checked the head pressure but I dont think I have an oil issue.So what does IA think?Reps for the help.Thank you in advance
    If you know better do better!
    is better than you..
    Somewhere you're not
    have you checked if the grounding is good? also you might want to make sure you have plenty of vtec fluid....
    What ground should I check?The vtak fluid is full silly that is the first thing I ckecked.Its the canister near the fuel injector fluid right?
    Check oil pressure in the Head... Also do so when oil temp is up!!
    What should the pressure be?
    Should be 7 psi or less at idle and it's supposed to read approximately 55 psi. at 5,000 rpm. Thats at the Head...
    JDM TYTE AnthonyF's Avatar
    Def check the oil. If your oil is fine, could be the solenoid it self. Just get another one from a junk yard.
    -Ant.
    The Carbon Fibered R6
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    try cleaning the solenoid out...
    98 Acura Integra LS-DD
    ??????????????????-project
    DRVEN ER OTHA DAY tubby's Avatar
    otp
    im having the same problem wit my b20vtec. i have checked all of those things and still no vtec..
    loose wires? clogged vtec solenoid..
    /Oo ___A___ oO\
    |=_/_______\_=|
    BC built head mmmmmm babyblueS2K's Avatar
    marietta
    if its not a clogged solenoid, replace the v-tec pressure switch.
    Well i have done all the testing according to honda its a bad ecu.I think it has gotten wet some how.thank you all, reps for al
    Senior Member G.C's Avatar
    Forgot
    Why do people keep on saying clean the solenoid.... If you clean it with any part cleaner, your going to damage it. That part is NON- SERVICABLE. WHICH MEANS YOU DONT HAVE TO CLEAN IT. If it goes bad then its bad, you have to replace it. If the screen gets clogged, you have a bigger problem somewhere else thats making it clog.
    :idb:
    TALKING ROCK, GA
    Quote Originally Posted by G.C
    not true. i am a tech at honda. the vtec solenoids do get clogged due to sludge build up . i have fixed many of cars just by using some type of cleaner and cleaning them out. never had a comeback for it. you can replace if it still doesnt work after a good cleaning but hey its worth a shot
