Results 1 to 5 of 5
Thread: little help
    IA Member RememberingNever's Avatar
    Cumming, GA
    Exclamation little help
    ya i posted in the stereo section but hey maybe ill get an answer here...
    amp is bein a bastard...
    i connect everything you know power to battery, audio wire from head unit to amp, speaker wires to subs...but then when i connect the ground wire anywhere, the little green power light on the amp turns off...
    any advice would be greatly appreciated
    __________________
    "I would never do crack... I would never do a drug named after a part of my own ass, okay?"
    http://www.myspace.com/now_until_forever
    constant 12v to batt (use large gauge wire for this/fused).
    remote turn on from head unit (if turning on more than 1 amp a relay is good to use).
    rca's (self explanatory).
    speaker leads (self explanatory).
    ground (to a good exposed metal surface of the body).
    if that doesn't work you've got a bad amp or doing it wrong.
    You best bet is to take a self tapping sheet metal screw and find you a spot that isn't going to intrude on anything else and tap your ground into the body somewhere that way you have a good solid ground connection if that doesn't work reply here and I will see if I can help you further. Also check your fuses make sure none are blown.
    Cumming, GA
    haha thanks for the input i found a 1 inch gap in the metal on the remote wire n there wasnt anything wrong with the insulation...weird but problem solved
    awesome.. that sux man but good thing you figured it out...
