Results 1 to 14 of 14
Thread: What do you use to attach your Lip?
    Monore/Atlanta GA
    Default What do you use to attach your Lip?
    I just installed a WW Lip on my Integra. Right now it's screwed on but I know they can get stolen and I want to make it more permenant after I get my alignment. What are some things you have used to attach lips to the frontend a little more semi permenant.?
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
    R A W! x Resilience's Avatar
    Atl
    Two sided tape?
    You niggas know my pyroclastic flow, its R A W!
    - Current: E36
    Out in the Boonies
    I used black hex screws. It'll take a little more than just a screwdriver/flat head to get the lip off. Unless they break it off ...
    Monore/Atlanta GA
    Quote Originally Posted by x Resilience
    Two sided tape?
    Yea, it has that but i am more concerned about it getting stolen and the tape won't help that
    Senior Member G.C's Avatar
    Forgot
    :idb:
    3m double sided tape, 10mm nuts AND bolts, and then screws. if you want more security use rivets as added security
    IA Member Hachigo Pro's Avatar
    Sep 2008
    rivets and lots of them.
    1986 AE86
    Atl
    Quote Originally Posted by jwrape
    Im pretty sure if they wanted your lip they would take the car along with it.
    - Current: E36
    Athens/ATL
    I've never had a problem with lips or spoilers getting stolen. If you're that concerned, definitely go for either hex head screws or see if you can get some small security Torx nuts and bolts to hold them on maybe? If they really want it, they're gonna get it.
    North Augusta, SC
    jb weld and gorilla glue ftw...
    Back to being stock and slow
    roberta
    Quote Originally Posted by Motivation
    lol.but on the real that gorilla glue is some strong stuff.
    BB6er IMPORTchic's Avatar
    N. GA
    I used 3M tape on mine along with regular bolts on underside and screws under fender and when I went to take it off...holy hellatious.....it was a pain!!! That thing didnt want to budge! But yeah....like everyone else is saying.....if they want it bad enough..they will get it no matter what is holding it on! But whats the point of getting it if its going to be all destroyed...? They are going to be semi-careful....soooo I say no matter what all you do....use the tape....takes time to get off w/o snapping lip in half! =)
    Monore/Atlanta GA
    Well, I ended up using some Hex bolts to screw it on. I would use the double sided tape but I do like that I can remove it if necessary. For instance when i went yesterday to have it aligned. He was actuall able to drive it up on the rack without using both boards. Only one was uses. :-) After I got home I re-installed it with the new bolts.
    JDM TYTE AnthonyF's Avatar
    You can do this for a nice smooth look:
    1. pilot holes
    2. sink holes
    3. screw or bolt it through
    4. bondo to cover the hole
    5. repaint.
    -Ant.
    The Carbon Fibered R6
