Thread: Just bought used JDM motor
    Fuhgettaboutit. OhMyGodfather's Avatar
    Default Just bought used JDM motor
    2 things concern me
    1) the intake to the turbo inlet is sooty, and grimey, not BAD, but one would assume it would be clean with a filter
    2) the inside of the throttle body, after the butterfly valve has black slimey substance on it... now i know bad turbos put out traces of oil through the FMIC and piping etc, but is that just normal wear and tear from a boosted motor?
    its a sr20det from a silvia s13 btw.
    decatur
    who did you buy it from and did it come with a warranty?
    yeah 14 day startup warranty for the BLOCK all accessories are as-is
    i just want to know if the turbo is showing signs of death, before i swap the motor in, t25s are like a hundred bucks, not a problem, but i dont want to waste 2-3 hours and cut knuckles when i can do it in 10 minutes
    Your mom's bed
    then just replace it to be on the safe side, like u said T25's are only $100 bucks.
    they only give you 14 days to start it up?
    San jose, CA
    Who did you get it from?
