Thread: ECU PINS!
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    Default ECU PINS!
    can someone pleaseee explain to me how to remove the wires from the ecu plugs...i know this been covered a lot of times but i cant find a good write up anywhere.
    Senior Member rbf's Avatar
    Sep 2008
    Augusta
    Try Honda-tech it is all over that site.
    Senior Member G.C's Avatar
    Forgot
    its easy. i did it before. you first have to open the back side by pushing it with a flat head from the middle and push it upward. it will swing open. Then from there you can pull it out easily.
    :idb:
    Forgot
    The pins wont come out if you dont get the thing to swing open first. I tried it and it did not come out. after 30 min of messing with it i finally got how it works and from there it was easy to pull them out. Just keep on messing with them untill it flips open.
    :idb:
    man i just ended up cutting the wires. it works good so far.
    Sep 2008
    Augusta
    Quote Originally Posted by PTY_REX
    (not trying to be a jacka**) but why would you cut wires that can easily just be de-pinned?.Just make sure to solder them and not twist them together in electrical tape.
    Southside of The Jungle
    Quote Originally Posted by ed7_hatch
    I love soldering
    trust me, i didnt twiste them and taped them together.
    Sep 2008
    thank you for your sharing~
