I'm having some electrical problems with my 93 cx hatch (b18b1 swap). Turning the key to on the main relay buzzes, and the CEL flickers. Fuel pump is not priming. Engine turns over, just no fuel. Confirmed fuel pump works, main relay tests OK. It's either ECU or wiring.... and I don't even know where to start with the wiring!
At the main relay plug, i am getting some weird voltage readings, and wonder if my ecu is messed up.
If somebody is running an obd1 swap, or a stock integra, it'd be a huge help if i could plug my ecu into your car, to confirm if it works. For helping me out, i'd happily present you with a case of beer.
I'm in dallas,ga (30132) and would meet you at your place, or you can stop by my place.
